S/N look up
Old 11-02-2012 | 08:17 PM
Default S/N look up
Can anyone help me look up a serial number 0W483547... Thanks.
FYI its a transom assy
1MOSES1 is offline
Old 11-02-2012 | 11:04 PM
Don't understand just what your looking for. A diagram of it?
http://www.perfprotech.com/mercruise...10/60?model=90
picklenjim is offline
Old 11-02-2012 | 11:30 PM
Sorry...should have been more clear. Looking for model and year (I.e. bravo one standard, bravo one magnum, bravo one HP, etc).
1MOSES1 is offline
Old 11-03-2012 | 07:46 AM
Mbam's Avatar
Offshoreonly Advertiser
Thats a standard transom with smartcraft senders
TRN: 0W483547 6315001TS MERCRUISER BRAVO SMARTCRAFT, late 2005
Mbam is offline
Old 11-03-2012 | 08:38 AM
Thanks for the info but looking up 6315001TS it says its a magnum transom assembly?
1MOSES1 is offline
Old 11-03-2012 | 10:37 AM
If you look it up on the brunswick website, Model number 6315001TS comes up as an MERCRUISER SMARTCRAFT TRANSOM W/ENGINE BRAVO SMARTCRAFT
Boatswainslocker.com appears to have model number 6315001TS listed incorrect to me.
Try running your serial numbers through this link,
https://webapps.brunswick.com/litera...atureSearch.do
lakematdude is offline
Old 11-03-2012 | 10:47 AM
arent all smartcraft magnum? thought the smartcraft was usually tied to a 496. if you google 6315001TS several boats with 496 are listed with this part number.
http://www2.best-boats24.net/pl/kupi...&oa_langcode=1
http://www.euronautica24.com/Advert/...aProizvod=1877
1MOSES1 is offline
Old 11-03-2012 | 10:58 AM
6315002NZ - TRANSOM ASSEMBLY, SmartCraft (496 and Digital Throttle/Shift)
6311002NZ - TRANSOM ASSEMBLY, Magnum (All - Except 496 and Digital Throttle/Shift)
1MOSES1 is offline
Old 11-03-2012 | 12:19 PM
Are you thinking a 496 "MAG engine" HO 425 HP B3X should/would automatically come with a mag transom assembly? If so, that would not be the case.
In the link below you will notice your serial number utilizes the bigger U-bolt & Nut like the mag T/A. item numbers 24 & 25,
http://www.mercruiserparts.com/Show_...Steering+Lever
Also take notice of the ( ) between the (Magnum Transom) & (SmartCraft) SN# 0W465665 & Up indicating two transom designs.
Another thing you can do in the brunswick website link is open Product Line, go to MERCRUISER 1998+, scroll down to "BRAVO", Click on the first BRAVO you see just under blackhawk, there you'll find a list of T/A model numbers. You're model number & all the model numbers you posted can be found in there as well along with basic information about them.
Old 11-03-2012 | 12:39 PM
I just confirmed the assy's I have are magnum style. The tell tale sign according to merc's service manual is to look at the gimbal ring where the Hydraulic rams attach. If they are ribbed it's standard. If it is solid then it's magnum. Mine are solid so I'm good to go. Thanks.
1MOSES1 is offline
