32 outboard test run >
Old 11-02-2012 | 08:28 PM
Default 32 outboard test run
Here is a link to a youtube video I took last week. I Finally have my Dewald 4 blade props running fster then my Mercury 3 blades. David possibally some more motovation for you. Your boat is in good hands at Skater. Make sure to watch the video in 720 hd.
http://www.youtube.com/watch?v=ftwuiX086Uk
Carl
chardt is offline
Old 11-03-2012 | 07:56 AM
Very cool !
Who built the strokers and did you ever run this boat with twin stokers ?
KEVLARKAT32 is offline
Old 11-03-2012 | 08:09 AM
davidmercury's Avatar
Carl that is awesome! I take it that you are running 15X34's?
davidmercury is offline
Old 11-03-2012 | 09:18 PM
The boat has always had triple 300x motors (rigged at skater), I have never ran it with twins. I am running 14.625x34 four blade dewalds. I have ran 14.5x34 3blade cleavers also; any bigger diameter prop (15") picks the back end up too high. (I have tried almost every combination possible, I have 14 props for the boat) I built the strokers last winter with alot of advise from Eric Simon who also reprogramed my ECU's. I have about 50 hours on them this season with no problems.
chardt is offline
Old 11-04-2012 | 08:15 AM
what is the best top to date with strokers and what was best top speed with stock 300x ?
What do you think the hp is per stroker ?
Larry
Old 11-04-2012 | 01:26 PM
Larry,
Best speed to date is 123.5mph with 50 gal of fuel and 200 lbs of gear on an average air day (29.4"hg). I do most of my testing on a small 2 mile long lake so I run out of space fast. (lake Michigan is normally not very cooperative) Before the strokers my best speed was 120 mph (perfect day light load 50 degrees out and a tail wind), but with the strokers I can hit 120mph on a 80 degree day with two people and 50 gallons of fuel. I didn't notice a lot more speed on the big end but acceleration and load carrying capability is better. I would expect more top end gain on a twin engine boat like yours. My boat feels like it hits a wall at 120mph, it has been very hard to get those last few mph's. Eric simon tell me the Horsepower is around 375 at 6950rpm, the motors like to run around 7000rpm. I tried proping at 6600rpm; the motors lugged, felt slugish and I could only hit 119mph.
Carl
chardt is offline
Old 11-04-2012 | 08:02 PM
alot of good info Carl, Thanks for the motivation, it'll be interesting to see what works with my set up
Old 11-13-2012 | 08:50 AM
TeamSaris's Avatar
Driver-441
Racer
AWESOME! 32s deserve triples.
TeamSaris is offline
