prop slip % ?? >
prop slip % ??
prop slip % ??
Old 11-05-2012 | 09:35 PM
Default prop slip % ??
what % of slip would be considered average & what would be considered bad ? what is the lowest prop slip % that anyone has seen ?? just very courios !!!
dave269 is offline
Old 11-06-2012 | 01:32 AM
IMO 15% would be considered average. Anything around 10-12% is considered excellent and anything 20% or above poor. Im sure others will chime in but thats always been my understanding...
Powerquest_Baby!! is offline
Old 11-06-2012 | 01:34 AM
That depends on what type of hull.
On the boat in your profile, probably something around 10% is normal.
Griff is offline
Old 11-06-2012 | 11:28 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Everybody wants/expects 10%.
More often than not, you will run above that number.
Cats will tend to run better slip numbers than V's at WOT.
Don't get to obsessed with slip numbers if everything is running and carrying well and you are under 16%.
Small adjustments can make big changes.
Brett
[email protected]
bbladesprops is offline
Old 11-06-2012 | 01:45 PM
was curious about that...thanks,Brett
pqjack is offline
Old 11-06-2012 | 09:14 PM
I run about 5% slip. Hering props setup by Brett
26awesome is offline
Old 11-07-2012 | 08:23 AM
Less on cats, more on Vee.
Pismo10 is offline
Old 11-07-2012 | 10:37 AM
On my straight V Formula 292 I'm at 13% with Hydromotive QIV's
endeavour32 is offline
Old 11-07-2012 | 12:44 PM
Hello;
What is average slip at 30 and 40 mph, if it is 12% at 70 mph?
sinus is offline
Old 11-07-2012 | 12:50 PM
Smile
There is no real average but it almost always higher.
Typically in the mid 20% range.
B
[email protected]
