Tunnel Ram & 2 4's >
Tunnel Ram & 2 4's
Tunnel Ram & 2 4's
Old 11-06-2012 | 12:27 AM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Tunnel Ram & 2 4's
Why don't i see this on bigger cubic inch marine engines ? Would this help a 540ci and bigger breathe ? I just need to know . deep
the deep is offline
Old 11-06-2012 | 06:41 AM
The RPM range for tunnels rams is higher than most boats use...
ezstriper is offline
Old 11-06-2012 | 07:53 AM
Every dyno test I've seen shows that tunnel rams are as good as dual plane on the low end and better than single planes on the top. I know Engine Masters magazine did some side by sides and the tunnels worked best overall by a significant margin.
ThisIsLivin is offline
Old 11-06-2012 | 09:26 AM
the deep's Avatar
Fast Singles Club
It would be nice to see some real world numbers by our own engine masters . Would there be an advantage only spinning the rpm's to 6,000 ? Thanks
the deep is offline
Old 11-06-2012 | 10:53 AM
Knot 4 Me's Avatar
Idle characteristics?
Knot 4 Me is offline
Old 11-06-2012 | 11:15 AM
gary cook's Avatar
Racer
Racer
I have a tunnle ram on my 588 ci 14 to 1 engine idle in cold weather can be a little fun works best in upper rpm .
When i built my 588 i went big bore short stroke so i could rpm it to take advantage of the tunnle ram.
Nothing like a big chevy at 6800 rpm sounds cool.
Go to 2012 loto part 1 on you tube we are about the 15th boat running sounds cool.
gary cook is offline
Old 11-06-2012 | 03:34 PM
the deep's Avatar
Fast Singles Club
That's definitely a chest thumper bro !! Nice work . Would you post a pic of your engine ?
the deep is offline
Old 11-06-2012 | 05:42 PM
GPM
We converted tunnel rams to EFI, they make good power. I would think with the right carbs and proper tuning they would work just as well.
GPM is offline
Old 11-06-2012 | 07:54 PM
gary cook's Avatar
Racer
Racer
I agree i took the boat out the day i left for loto with a fresh engine drove it around for 20 min to break it in did a couple of speed runs with wide band on it to make sure air fuel was ok.
We broke a 100 mph so i new i could step up the record from last year so i did no more tuning that being said it ran ok with out of the box gary williams carbs and would idle around at 1000 rpm .
If you fuel inject it a lot of problems go away.
But to get the real advantage of a tunnel ram be ready to turn some rpm so dont scimp on the valve train.
Old 11-06-2012 | 08:17 PM
Rookie's Avatar
JimV (Valako) runs a Holley Dominator tunnel ram manifold modified for EFIon his 565 with twin 1000cfm throttle bodies. I believe the dyno was 787HP@6200. And it was not lacking torque. They make power. Last year he tried twin 750 carbs and lost power.
Rookie is offline
