Tunnel Ram & 2 4's
www.michiganmafia.net
I will try to find some pictures of it in boat complete/
reviving an old thread... looking to unleash some more power from my 557's N/A motors,, anyone else running a tunnel ram set up with dual carbs? in the 800hp range? or should I just add a pair of blowers ?
Tunnels are better theory. In practice, due to class rules, lots of really good 1x4 BBC manifolds get developed. There are fewer tunnel ram options, but with some work they should always end up best.
Not willing to cut hatches... sunpad is essential , lots of blower options that will fit under hatch, but just don't think it will fit with a any type inner cooler /chiller , obviously a blower would easily exceed my HP goals .. just exploring all my options.. I very confident my hull would respond nicely to an extra 100hp a side
If I was building some bigger power NA engines, I would be doing tunnel ram intakes. For a few reasons.
#1. Fuel Distribution. The individual runners with twin carbs, much better fuel distribution to all 8 cylinders.
#2 . Powerband. Contrary to popular belief, tunnel rams arent just for 7500RPM big blocks. Often, they make more power from 3000-6000rpm, over a single plane.
#3 They simply look cooler IMO, than a single 4 barrel setup.
Some good info here. They had a 540ci, 8.8:1 compression, 271/280 .742/.715 lift cam , Dart 355 cnc heads.
Weiand Team G single plane with dominator = 770HP/663 TQ
Weiand Tunnel Ram, twin 950 carbs = 777HP/681 TQ
Dart Tunnel Ram Twin Dominators= 806HP/694 TQ
Dart Tunnel Ram ported by Wilson = 833HP/712 TQ
The Wilson ported combo is up a solid 50hp at 6000ish rpm, and 30-40ftlbs thruout the midrange. Doesnt look like it gives up anything anywhere to the single plane setup.
