dead spot on throttle advance 496 ho >
Old 11-11-2012 | 07:55 AM
Default dead spot on throttle advance 496 ho
When winterizing i noticed there is a dead spot when advancing the throttle on my 496ho . As i advance, it will slowly advance to 1000 rpm and then its dead till 2000 rpm where it just jumps to 2000. I cant run it at 1500 rpm , Its 1000 or 2000. But seems to be normal above the 2000 mark.
Any thoughts, think its throttle position sensor.
Allicat38 is offline
Old 11-11-2012 | 03:17 PM
MER Performance's Avatar
I believe, you are on track.
MER Performance is offline
Old 11-11-2012 | 06:47 PM
Noticed that today with mine. Does the exact same thing. Can move throttle up to about 1000rpm then it jumps right to 1800 to 2000rpm. I wonder if it is normal for it to do that? Winterized mine today so i wont be restarting mine for a few months
longtravel is offline
Old 11-11-2012 | 07:18 PM
just had mine running today also and it did pretty much the same, always has, when under load it doesn't do it at all, just reving in neutral
blownhammer2000 is offline
Old 11-12-2012 | 05:18 PM
The min i can run is like 2800 under load so i never really noticed any problem. It must not have done last time i ran it out of the water as i did not notice it. I also noticed this year as i was comming off of full throttle a few times it seemed like that motor would come down at a different rate than where the throttle was till i slowed down alot towards cruising rpms 3400.
Old 11-13-2012 | 08:29 PM
mine does something similar it doesnt seem as drastic, it's probably just the ecm going into closed loop or something of that nature
gotstreetracin is offline
Old 11-14-2012 | 02:26 AM
KernWillia is offline
