454 420 hp more power
Mark IV, change to a nice roller cam set up would be my first change. If the bank has the money to go deeper aluminum heads and some pistons to up the compression to around 9.5:1. You got a good basis to work with there.
it a 1979 454 420 hp motor with about 400 hrs would like to get to high 400 hp or 500 hp what cam would you suggest also heads and pistons
If they run strong and are healthy right now, bolt on and go. Of course there will be an endless list of "should do's" but if there are no issues right now might as well make some
Jk the engines will be fine with a 174, or 250 blower.
