Go Back  Offshoreonly.com > Owners Forum > Powerquest
Anyone have any updates planned over winter? >
Old 12-05-2012 | 08:53 AM
Default Anyone have any updates planned over winter?
I bought a tow rig to drag the boat around. Also did the following below.
Replaced the sea water pumps with Hardin Marine pieces.
Replaced the spark plugs.
Replaced both bilge floats.
Installed fan in cabin.
Cleaned both K&N filters.
Cleaned bilge
Removed, bead blasted, and reinstalled bilge plugs and replaced cables for oil change tubes.
Installed relay for engine hatch.
Drive service.
Oil change.
Things still left.
Need a couple bunks raised on the used trailer I bought.
Tires on the trailer
Have the extra drive I have checked out (just in case)
Then ill be ready to go for 2013!!!
Pwraddr is offline
Old 12-05-2012 | 12:58 PM
This is my plans for the winter:
-I'm pulling the top ends of my 525's for a refresh.
-Not sure but I may get some intake and head work done while there off for some additional power, looking to bump them up to 590-600hp.
-Replacing both lower drive housings with new units while drives get a going through and rebuilds.
-Relay for engine hatch.
-New props
-Injectors cleaned and flow tested
Come on boating season!!
verbi69 is offline
Old 12-05-2012 | 02:15 PM
fantastixvoyage's Avatar
Verbi - let me know when you are ready to have those heads ported. have a fantastic guy here in detroit
fantastixvoyage is offline
Old 12-05-2012 | 02:56 PM
Curious who your guy is??
Pwraddr is offline
Old 12-05-2012 | 05:43 PM
-New props
I have a lot of plans for boatnt
PWRQUEST is offline
Old 12-05-2012 | 05:55 PM
F-2 Speedy's Avatar
Two new B. M. spec'd 540's for me
F-2 Speedy is offline
Old 12-05-2012 | 06:04 PM
Lol....he does keep you busy!
Shouldn't he be looking for a new boat!!
verbi69 is offline
Old 12-05-2012 | 06:05 PM
I started to drool after reading this!
verbi69 is offline
Old 12-05-2012 | 06:06 PM
Originally Posted by pwraddr
curious who your guy is??
x2.
verbi69 is offline
Old 12-05-2012 | 08:28 PM
x2.
He worked for Sterling when I did and now works for himself doing work for many of the areas top builders. He's done several sets for me and always surprised with the power.
