Could m3 prochargers make 800 hp on 509ci motors making 640 hp Already
My motors are 509ci with pro 1 dart aluminum heads and cam work the motors r making 640 hp now with the m3 prochargers andmefi3 computer I should be able to make 800 plus hp right
Thanks a lot
C Roussel
Thanks a lot
C Roussel
absolutely! Without a doubt! Just be sure you have the right Cam selection. I dont know anything about the fuel injected side of things but I am sure there are a few people on here that can answer those questions. I have 522's that made well over 1200 HP with the M4's and I know a few people running M3's making around a 1000 HP with 509's to 516's....
You better have premium parts, proper assembly, correct injectors, and a proper tune.
Het tunnel, did I hear that you have the edelbrock aluminum heads? I also have a 509 with an m3 and the edelbrock aluminum heads. I would like to make 1000hp and wondered if these heads are up to the task? Also would you recommend the blow through carb setup, or stay with injection. I am running around 675hp now, with the factory injection setup. Not sure if I should go to the blow through setup, or modify the injection setup for more power?
The real question is, what is your combination now? Compression, cam specs, and so forth. That will give a idea of how much boost you can run.
Yes Smitty and I have been talking a fair amount. Great guy, very smart. I was thinking of staying with the injection, but at over 1200hp with a blow through setup and 522ci. I felt I should at least discuss the option of a blow through carb as well. I guess I have been feeling if my end goal is 1000hp, maybe I should swap the merc injection for a direct injection intake, with a blow through throttle body?
