Amber like material in exhaust >
Old 12-06-2012 | 11:01 AM
Default Amber like material in exhaust
Ok, this one is baffling. I just pulled both my 525EFI's for some winter work and both, including the one rebuilt last spring have a bit of amber like material in the exhaust ports of the heads. I searched around online and found a few other people with the same thing, but no answers on what it is. Maybe something from the fuel? Anyone have any ideas???
EdNewman is offline
Old 12-06-2012 | 11:28 AM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
That could be residue from evaporating water . Did you pressure check your headers ?
the deep is offline
Old 12-06-2012 | 04:07 PM
They are Hardin, and I check them every winter. Plus, it is in almost every cylinder (varying amounts) on both engines. Only thing that makes sense is something in the fuel.
EdNewman is offline
Old 12-06-2012 | 04:59 PM
the deep's Avatar
Fast Singles Club
I see said the blind man . Anything laying in the exhaust ports should have passed through the combustion process and hence be exhaust smoke or carbon . My conclusion is the same but i'm just a nobody trying to help you . What do your spark plugs look like ? They usually have a story to tell .
the deep is offline
Old 12-06-2012 | 06:06 PM
if you can post a pic it would do a lot better then us guessing what it is...
FIXX is offline
Old 12-07-2012 | 08:57 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Is it the pink/amber dye from the antifreeze?
Sydwayz is offline
Old 12-07-2012 | 04:08 PM
EdNewman is offline
Old 12-07-2012 | 04:09 PM
The texture is also what throws me. It is soft, like amber, not hard and crumbly like salt.
EdNewman is offline
Old 12-07-2012 | 04:47 PM
looks like condensation,,where you located?
FIXX is offline
Old 12-07-2012 | 05:37 PM
i also see white stuff around the end of the valve seat,and looks like a lot of rust on the freeze plug,strange since they are brass when they leave mercury.
mike tkach is offline
