Amber like material in exhaust >
Old 12-07-2012 | 06:04 PM
Wink
Originally Posted by mike tkach
i also see white stuff around the end of the valve seat,and looks like a lot of rust on the freeze plug,strange since they are brass when they leave mercury.
I think that's a head bolt washer you are seeing.
Eddie
Young Performance is offline
Old 12-08-2012 | 08:41 AM
Eddie
I agree
smiklos@sunprint is offline
Old 12-08-2012 | 08:51 AM
Eddie
yes,its to high to be a freeze plug.
mike tkach is offline
Old 12-08-2012 | 11:09 PM
Yes, that's a head bolt.
EdNewman is offline
Old 12-09-2012 | 08:20 AM
could a small amount of reversion,be causing this???
TWIN-SPINS is offline
Old 12-09-2012 | 09:08 AM
Possible, but it is on all 4 sides. And wouldn't it be salt then? I'm still thinking some sort of fuel additive.
EdNewman is offline
Old 12-09-2012 | 12:17 PM
Do a bleed down test, my bet is reversion and leaky valves. I have seen this on several 525's with high bleed down numbers, some over 50% with less than 150 hours on them.
brian41 is offline
Old 12-09-2012 | 09:22 PM
I finished breaking down the engine. There was some salt residue on the exhaust runners. Maybe it is reversion an just something in the water.
EdNewman is offline
Old 12-09-2012 | 10:29 PM
PSI check your headers if you haven't done so to rule that out.
MILD THUNDER is offline
Old 12-10-2012 | 02:44 PM
Have not done yet, but I am now in the tiresome habit of pulling and testing them every winter, even with the new Hardins. So far they have been good, just one pin hole.
EdNewman is offline
