42 fountain questions
Old 12-12-2012 | 04:26 PM
GDM
Default 42 fountain questions
hello , my 45 excalibur got wrecked in hurricane sandy
Im looking at a 42 fountain lightning and I have 3 questions
1 - how fast will it be with 500hp's
2 - it only has a porta potty and I want to convert it to a flushing toilet with a pump out , is it doable/feaseable
3 - it doesnt have a generator , would it be difficult to add it ?
thanks in advance
GDM is offline
Old 12-12-2012 | 04:34 PM
The best deal on a 42 is right here. Owner is crazy meticulous.
http://www.offshoreonly.com/classifi...o48186-en.html
Mastercraft240 is offline
Old 12-12-2012 | 04:56 PM
GDM
not what I am looking for but thanks
GDM is offline
Old 12-12-2012 | 05:03 PM
2 - it only has a porta potty and I want to convert it to a flushing toilet with a port a potty , is it doable/feaseable
thanks in advance
How fast depends on the year of the Hull. With 500's, maybe mid-upper 70's
Adding a flush toilet and generator can be done. Depends on what you consider hard work.
MILD THUNDER is offline
Old 12-12-2012 | 08:54 PM
tomtbone1993's Avatar
thanks in advance
70 Plus
yes with some minor glass work
no
tomtbone1993 is offline
Old 12-12-2012 | 10:45 PM
i know a guy with a 2000 42 with hp500s,top speed is 82 gps.
mike tkach is offline
Old 12-13-2012 | 01:31 AM
GDM
thanks for the feedback
the boat is a 98 and the guy claims it does 80
GDM is offline
Old 12-13-2012 | 05:31 AM
hammer01's Avatar
Its a great hull and from experience with my friends boat runs 70-75 stock. With gen upgrade etc, Mild Thunder can def give you great hands on advice, he is the man!
hammer01 is offline
Old 12-13-2012 | 07:41 AM
I had a later 2000 35 with the large steps and hp 500's, ran 85, 42 is alot more boat
JMPH is offline
Old 12-13-2012 | 08:12 AM
An option for your 2nd question - They make a pump-out porta potty with electric flush now. It mounts right where your current potty is and has a hose that mounts to a thru-hull fitting for the pump-out. The holding tank holds 5.5 gallons of waste. They actually look pretty cool and it would be much easier than installing a true pump-out system. Just an option.
Porta Potti 465 MSD - Portable Marine Toilet
Designed to Make Dockside Pumpout a Breeze
This durable toilet is sanitary, odorless and leakproof. Plus, high-gloss finish is easy to clean!
• Electric pump quickly and easily flushes fresh water to clean bowl
• Removable seat and cover for easy cleaning
• Sealed valve keeps odor in holding tank
• Built-in deodorant storage (bottle included)
• Hold down kit secures toilet to deck
• Easy-to-read Level Indicator tells when its time to empty
• Capacities: Fresh Water: 4.0 gal: 15 L
Waste Tank: 5.5 gal: 21L
TCBoss302 is offline
