Firestone or Airlift bags
Old 12-15-2012 | 07:05 AM
Default Firestone or Airlift bags
Has anyone used either of the two products. I am looking to put these on a chevy 2500hd but ant some feedback if anyone has used either. Pros and Cons of both I will put the compressor kit on also.
353Formula is offline
Old 12-15-2012 | 07:15 AM
I used the air lift kit on my 3500 dually. I put them on because I lowered my dually and removed some of the leaf pack so I wanted to offset the loss of weight capacity wi the air bag. It was an easy install (I had the bed off) and they work great. Really improved the ride quality!
The air compressor is also a nice option.
502ss is offline
Old 12-15-2012 | 07:41 AM
The air lift kit for 2500 hd's is as simple an install as it comes. They work well, but I've had some dry rot cracks become evident after a couple years. Not sure how long the Firestone bags last, but most big truck airbags are Firestone.
Unlimited jd is offline
Old 12-15-2012 | 08:20 AM
I installed the Air-Lift system my '11 F-150. Its simple to install-took about 4 hours with the wireless compressor kit. My compressor went out about 1 year later, but Air-Lift replaced it for free.
The bags between Firestone and Air-Lift are similar, but Firestone has a better compressor.
Addicted is offline
Old 12-15-2012 | 09:25 AM
I have over 1 million heavy towing miles on the firestone ride rite bags. The same pair has been transfered to multiple trucks. Love how stabil they feel. Handle loads better. Reduce sway. Overall ride is good. Empty ride will not improve like some think. Will be about the same if the pressure is dialed in to your liking.
offshorexcursion is offline
Old 12-15-2012 | 09:38 AM
Firestone Ride Rite are really good. Put them on my old truck and there were great for leveling under load. I didn't install the on board compressor. I bought a small rechargable compressor that I could just carry in the truck any time I needed some air. But most of the time I just left them at the same setting. They are simple to install.
MonkeySea2 is offline
Old 12-15-2012 | 11:50 AM
i was told that firestone made air bags for air lift...just make sure you keep 20 psi in them at all times or they will rupture..
FIXX is offline
Old 12-15-2012 | 12:15 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Firestone does make them both.
Sydwayz is offline
Old 12-15-2012 | 05:09 PM
I "heard" you must always keep 10psi BUT I lower mine to 2-5 psi when empty often and have been doing so for years with no problems. Zero Problems.
Old 12-15-2012 | 06:30 PM
Actually the air compressor I have has a pressure switch which automatically turns the compressor on if the bags drop below 15 psi
502ss is offline
