502mpi v belt setup to serpentine setup like 98-00 502 mpi's?
Has anyone went from a v belt setup to a serpentine setup? If so I need the pulleys and what not to do it my father want to change over to a serpentine setup to run his procharger
I did all my own. if you need custom brackets just make templates from wood or like I did from plastic. I have a couple crank pulleys left from doing this. I think they are 6 rib. if you go to the link below you will see the plastic I used.
http://www.offshoreonly.com/forums/s...ck-motors.html
