Ok to replace grade 5 and 8 bolt with stainless >
Old 12-21-2012 | 10:43 AM
Default Ok to replace grade 5 and 8 bolt with stainless
Okay as many of you know I am dressing the outside of my motor with all billet parts when I go to put the bolts back on I would like to replace them with stainless instead of bronze on exterior motor parts will this be an issue? Pulleys, alternator brackets, etc
FuelinAround is offline
Old 12-21-2012 | 11:16 AM
Fenderjack's Avatar
Pirate of the Chesapeake
Nope go for it ! Just don't do the head bolts LOL.JOHN SR
Fenderjack is offline
Old 12-21-2012 | 01:44 PM
Yup go for it!
When I rebuilt my engines I replaced every bolt with stainless Allen bolts and stainless washers.
I even put stainless bolts in areas like the face of the cylinder heads where there were just threaded holes but nothing in them! I think it added a level of dress up and uniformity. You can see the bling in the photo!
What I wasn't expecting was the $450 dollar tab I had run up at my local nut and bolt place!
502ss is offline
Old 12-21-2012 | 03:48 PM
MOP
Thumbs up
YES!!! http://www.totallystainless.com/ Is absolute best supplier, I did the full engine kit for my 383. That was 5 years ago, they are the only company licensed by ARP. I have recommended them to quite a few also very satisfied guys. They carry something for every application, wait until you get a catalog!!!!
Phil
MOP is offline
Old 12-21-2012 | 04:50 PM
ARP is the way to go. Stronger the grade 8 also. I do all my engines with them. Not cheap though.
F357 is offline
Old 12-21-2012 | 05:27 PM
tcwcar's Avatar
Joe
Yes to totallystainless close to me, we use them all for the cars in my resto shop, call and get there catalog, they have complete kits, single items, also have grade 8 or harder bolts, and every type of bolts, washers, nuts, you can think of, and standard ss bolts are not hardened, in fact if you buy bolts off them they will ask you what your using them on, wont sell you standard ss bolts if your going to use them on any steering or suppention work, got to get the hardened ones from them...
tcwcar is offline
Old 12-21-2012 | 08:03 PM
I would say yes and no. it depends on where you are buying from. a quality bolt shop should have a pretty good grade of stainless but I have seen some at hardware stores that were pretty bad quality and very soft. the parts you are bolting on are not very high stress so as long as they are decent quality you should be fine.
compedgemarine is offline
Old 12-21-2012 | 08:24 PM
Use anti seize
goebel1 is offline
Old 12-22-2012 | 07:59 AM
I have using boltdepot.com for years, can buy what you need 1 to 1000 great selection !
ezstriper is offline
Old 12-23-2012 | 12:08 PM
C_Spray's Avatar
Diamond Member #001
If you're running in salt water a lot and the aluminum parts are not coated or anodized, consider using Tef-Gel in between the bolt and the part. Aluminum and stainless are at opposite ends of the galvanic scale and will corrode together very badly in the presence of salt water. By "badly", I mean that they will virtually weld themselves together...
C_Spray is offline
