manifold - riser replacement >
Old 12-27-2012 | 05:46 PM
Default manifold - riser replacement
hello fellas,
I have a 496ho with 85hrs on it. it is used in salt water. My question is, when is it time to change the manifold and/ risers? is there a calendar and time limit like with other components? and should both the manifold and riser be changed or only one of the two?
CafeRacerPTY is offline
Old 12-28-2012 | 01:52 AM
As long as you are flushing them after each use, you should get at least 5-8 years out of them.
Griff is offline
