Crane hi6 ignition box >
Old 01-06-2013 | 08:09 PM
johnnyboatman's Avatar
Default Crane hi6 ignition box
Which wires goes to the distributor?
johnnyboatman is offline
Old 01-06-2013 | 10:29 PM
Rookie's Avatar
Are using the HI6 or HI6M. Are you using the hall effect TB distributor? Did you phase it?
I believe the HI6 uses the Violet (+) and Green (-)
http://www.sportcompactonly.com/manu.../90006000e.pdf
HI6M White/Green White/Red
http://www.sportcompactonly.com/manu.../90006462b.pdf
Rookie is online now
Old 01-07-2013 | 09:45 AM
Rookie thanks its the marine version, i looked last night and over looked it.
Old 01-07-2013 | 11:43 AM
Rookie's Avatar
This winter I am going to try to hook up a knock module and sensor. So when the module sees knock from the sensor, it will source voltage to a relay. Then the relay source (-) to the HI6M brown retard input wire and the retard ignition timing to what I set on the box.
