Mercury Scanner questions
Old 01-06-2013 | 09:07 PM
LubeJobs42's Avatar
Default Mercury Scanner questions
Last week my engines went into guardian mode.
I was screwed until I was abe to get TNT so they could scan and clear the codes.
I want to buy a Merc computer/scanner so i can have my guys scan and adjust the motors.
There are several for sale on Ebay but im not sure which will work.
Is there a specific model I need? Can they be updated?
I asked one of the sellers that says he was a Mercury mechanic if his computer will work with 1075's.
His response was "Whats 1075?"
LubeJobs42 is offline
Old 01-06-2013 | 09:28 PM
Boater8987's Avatar
Airking
Call Rinda to get all info and buy direct. I purchased the Diacom laptop version for my 600SCI's and 300 Verado's
http://www.rinda.com/marine/marinemenu.htm
Boater8987 is offline
Old 01-06-2013 | 10:06 PM
From: Ft. Lauderdale Florida & Tarpon Springs Florida
Whats' 600 Sci's and 300's ??
tanner is offline
Old 01-06-2013 | 10:29 PM
gino i have a merc set with the chips call me 954 2606982 pauly
GOFSTCAT is offline
Old 01-06-2013 | 11:48 PM
BUP
Agree with Diacom / Rinda. they are the cheapest priced plus very current with every marine EFI / MPI motor on the market including Ilmor. They can scan the very current catylist motors also. FYI they also can scan Merc Outboards. We use them with no problems and they have tech support if needed.
next is CDI MEDS they have a 6.0 dashboard version that works very well but they will not scan all motor brands nor the current Mercruiser Visteon controller / catylists motors. They are a tad behind on the very current systems but are trying to make head way. They are also twice as expensive compared to diacom / rinda.
They both do a good job but IMO, CDI MEDS does a better job persay pinpointing a problem with a sensor/s and or code/s. They do very well with MEFI 1 thru 4 and ECM / PCM 555 Mercruiser / Mercury outboards.
BUP is offline
Old 01-07-2013 | 12:10 AM
Audiofn's Avatar
Charter Member #232
Gino I have the RINDAH unit that you can barrow to see if it works. I think it is totally up to date and I have a number of different harnesses. It is up in Maine and I won't be up there for 2 weeks but if you are not in a rush you are welcome to try it out and see. I use it for my Optimax outboard but it also does a ton of other stuff.
Put your best foot forward!
Audiofn is offline
Old 01-07-2013 | 12:34 AM
[QUOTE=LubeJobs42;3843744]Last week my engines went into guardian mode.
At Mercury pricing, they should just have a guy strapped to the back of your boat to catch these problems on the fly!
AO31 is offline
Old 01-07-2013 | 07:54 AM
eddie's Avatar
I have the Rinda too, just upgraded my chips to scan the 300 Verado's the customer service is very helpful. You can get adaptors to run a bunch of different power packages, you will need the 94006 for the 1075 I believe:
http://www.rinda.com/acro/scantool_adapters.pdf
eddie is offline
Old 01-07-2013 | 09:43 PM
fantastixvoyage's Avatar
Anyone with the Rinda laptop version know if it show data while cranking or does it have to run? Reason I ask is i'm working on a MEFI motor thats not wanting to start and the scan tool doesnt seem to help much unless its runs. Had to go old school and break out the injector diode, fuel pressure guage, etc etc
Thinking of upgrading to the laptop version as the scan tool seems pretty limited in functions.
fantastixvoyage is offline
Old 01-07-2013 | 10:28 PM
LubeJobs42's Avatar
Thank you! I contacted RINDAH and they said it their system will work on 1075's. It's cheap enought, i'll order it.
Thank you for the info! I never knew they were out there!
Anyone know of a scanner that can help me read my wife?
(I figured it was worth asking!)
