Air Unit
Old 01-17-2013 | 01:09 PM
bill63's Avatar
Fast Priorty II Nor-Tech
Default Air Unit
Has anyone installed a aftermarket air cond. on a 42 easy,hard, expensive ?????
bill63 is offline
Old 01-17-2013 | 01:42 PM
Bill, captain Bob uses a floor type home ac and vents out the cabin door. Works awesome other than IMO transporting it. It wouldnt be ideal for a trip to PIB
drpete3 is offline
Old 01-17-2013 | 01:49 PM
I plan on removing this unit from its casing and integrating it into my cabinet by removing the cooler. It is the smallest one I could find. You can vent the hot air to the gun whale under the cabinet, and drain to the sink outlet. No water lines and cheap.
http://www.ebay.com/itm/Danby-5000-B...370#vi-content
4bus is offline
Old 01-17-2013 | 02:57 PM
bill63's Avatar
I am thinking that since fountain does put air in these boats as a option there should be a spot in the boat prewired for a unit.
bill63 is offline
Ran-Dom 32's Avatar
hatch drop in units work great! but I do like 4bus idea, let me know how that works out... I like the idea of the portable unit, only because you dont need to lug around a/c if your not planning to overnight
Ran-Dom 32 is offline
Old 01-17-2013 | 03:08 PM
All Fountain have an option for AC. All 47' come standard with AC/Heat
dewayne6243 is offline
Old 01-17-2013 | 03:25 PM
I have one of those units, except mine is a 8000 btu I believe. I keep it in my enclosed head all summer, surrounded by life jackets and noodles so it doesn't bang around. When it comes time to use it, I set it in the cabin entry way, on the step. I rig up some towels to seal things up, and let it run. It cools the cabin down nicely. Not ice cold, but comfortable. Crappy part is having to enter cabin thru deck hatch. Eventually I want to do a permanent install of some sort. My buddies with self contained units have it nice. Plug in and flip a switch. Ice cold cabin in short time.
MILD THUNDER is offline
Old 01-18-2013 | 07:44 AM
Talked to a friend last nite that has had 2 42s and says the factory installed unit is under his sink. Says water inlet is under the step. His current boat doesnt have air or I could go take pix.
drpete3 is offline
Old 01-19-2013 | 08:51 PM
bcfountain's Avatar
Registered User
I had thought about doing the same thing but did not know how well the componates would hold up under all the wave jumping.let me lnow howthat works out.
bcfountain is offline
Old 02-06-2014 | 08:59 PM
MT/4bus:
Did y'all ever install the portable a/c? I was thinking the same thing.. Pull from casing and mount under sink. Access to gunall for hot air and sink drain for water. Would are you running the unit on?? Inverter. If so how many watts needed?.
nailit is offline
