35 or 38 LIghtning >
35 or 38 LIghtning
35 or 38 LIghtning
Old 01-28-2013 | 08:15 AM
Default 35 or 38 LIghtning
Ok need some imput. Looking at a 99 35 Lightning w/ single step and twin 500hp's and a 2000 38 Lightning with twin step and twin 525sc's. I boat mostly on lakes with an occasional trip to coastal waters. I do participate in poker runs. I currently have a 30' Hallett and its nice but not fast enough. Help me decide.
682gold is offline
Old 01-28-2013 | 01:18 PM
Default 35 or 38
If the price is about the same the 38 would probably be the bettor choice. I have a 93 35lightning with HP500;s that will run in the low 80's. Not because i own one but i like the lines on the 35 bettor then the 38. The 38 probably has a little more room in the cabin and i would think runs in the high 80's with the 525's. Does either one of them have shore power which is a plus if you are staying overnight anywhere. What i am saying is if the 35 had shore power and the 38 did not that would be a buying perk for me. There are some variables to think about, fuel being one of them. My 35 with the hp500's uses between 65and 70 gallons cruising at 55mph on a Chesapeake Inn run which is just under 100 miles round trip. I would think the 38 would use more fuel then that with the 525's. Some things to think about. I am sure you will probably get a reply from someone with a 38 with that power package. Would be curious to see what you're choice is. (good luck)Sam
jackieboy is offline
Old 01-28-2013 | 01:37 PM
The best thing for me about the 38 is the fact that everyone has a 35 or a 42, 38s are semi rare. Just a little more room everywhere, but the 3 ft seems like a lot more than 3. Just as the the 42 seems like it is a lot more than 4 ft.
I think those boats will run near the same exact speed, 79-81 mph
4bus is offline
Old 01-31-2013 | 08:17 PM
I climbed inside both. The 38 had more headroom and seating in the cabin. The head had a sink. The 35 was about 3-4 m.p.h. faster with equal 525 motors. The 35 had a vacuflush head and a fridge where they were optional on the 38. As mentioned above options could sway a person either way. The weight was only about 4-500# difference so no big difference towing. Either would be nice IMO.
Wes Burmark is offline
Old 01-31-2013 | 08:21 PM
Bigger is better. At least in Texas
dewayne6243 is offline
Old 02-03-2013 | 08:31 AM
You didn't mention if the 38 was staggered, if so, that will make a huge difference in the ride and speed. 525sc's will be a little more costly to maintain.
SPEEDFREEK is offline
Old 02-03-2013 | 08:47 AM
A 2000 38 is side by side unless someone changed it.
Wildman_grafix is offline
Old 02-03-2013 | 09:12 AM
That 3ft is a huge difference everywhere!!!
jmoore1225 is offline
Old 02-03-2013 | 10:41 AM
38 for sure
runafever is offline
Old 02-03-2013 | 12:06 PM
42....lol
keegan is offline
