2X B&M Weiand or Holley 177's 250's or 420's >
Old 02-01-2013 | 12:02 AM
Registered User
Default 2X B&M Weiand or Holley 177's 250's or 420's
I have 2x new 177's ordered, they are on backorder until 2-27 though. I have two SBC's build ready to dyno just no blowers. This is the second time they have not delivered when promised.
Im entertaining the idea of something a little bigger then the 177's only because of the order status.
What do you have?
Mike
GTOKILLER is offline
Old 02-01-2013 | 05:19 AM
(2) Wieand 256, approx 50 hrs since freshen up with dual carbs on each,fuel lines, linkage, flame arrestors and instake manifolds. $ 6,000.00
Also (3) crane Hi-6m ignition boxes & coils $ 900.00
James is offline
Old 02-01-2013 | 07:20 AM
Registered User
Are they BBC or SBC manifolds? for what heads?
Old 02-01-2013 | 08:56 AM
wayne272's Avatar
What do you have?
Mike
If you decide to stay with the 177's I have 2 intercoolers for them in the swap shop.
wayne272 is offline
Old 02-01-2013 | 09:27 AM
Sorry, missed the SB line, these are BB intake manifolds. these came off 540 with 5 lbs boost, also have extra set small pulleys
James is offline
Old 02-01-2013 | 10:33 AM
Registered User
I seen them, Im interested just gotta figure out what direction in going haha. Thanks for the info Ill be in touch with you soon.
Old 02-01-2013 | 10:36 AM
Registered User
What carbs? Rec. port BBC intakes? I might be able to resale them. I have carbs but will need the 2+1 adapter to run a single 1050. Thanks
Old 02-01-2013 | 11:11 AM
blower shop 250s! They'd be sweet on your small blocks
MILD THUNDER is offline
Old 02-01-2013 | 11:36 AM
Registered User
Thats the direction im leaning, put some intercoolers under them & go!! got any 2+1 carb adapters laying around you want to part with?? Then ones I found have 2x 850 Nickersons, without coolers.
Old 02-01-2013 | 12:03 PM
I wouldn't be afraid to run the 250's with a pair of 850's. Its very hard to overcarb a roots setup. More carb then you need, but really wont have any adverse affects like it would on a N/A engine. Better fuel distribution too from the dual carbs.
Ive got some really cool info on B&M's lineup of blowers on small blocks from back in the day. I can email some of it to you if you want.
