2 stage KE waterpumps and Sportmaster LWP help...
Here's what i have Whipple charged motors with stage 2 intercoolers, trying to figure out how to plum the cooling system...I have 2 stage KE pumps, thought of 1 stage for the intercooler one stage for the motors, i have a pair of merc high flow sea stainers, and a knoched transom with not alot of room for water pickups...my question is are my sportmaster drives LWP going to be enough feed the strainers, then to the 2stage pumps 1 stage going to motors the other to the intercoolers??? the next question is, if it's not enough water through the drives to feed everything, and if do find some room on the transom to mount water pickups, can i plum the transom pickups into the water line coming off the drives with tee before the sea strainers to feed the 2stage pumps??? or maybe not what I'm thinking at all, if got a better way please let me know.....
The whipple kit that I have came with a pickup for the intercooler only & the instructions say to plumb it that way because the intercooler is not doing anything at idle or slow speed. As far as the LWP in the drive I was told that at speed it gives a ram effect literally forcing water through the cooling system. Maybe Dustin or some of the engine building members will chime in to verify. Randy
Thanks for the input Randy, i got the water pickups in the kit just not alot of room to mount them. i did talk to Dustin about it, he said give it a shot with just the water from the LWP off the drive, with the 2stage pumps feeding the motor and the innercooler and see if you have enough water pressure, but I'd sooner not leave it up to chance that it might work... I'm hoping some of the builders chim in..maybe i should sell the 2 stage pumps, use the single stage pump to feed the motors with the drives, try to get the transom water pickups in there, get some intercooler strainers, and feed intercooler with the transom pic ups..
I'll second the pressure fed intercooler. Eddie set my boat up that way as he doesn't prefer water at idle. I for sure think you'll need more water than can be fed through the drive. The restriction in the transom fitting is not going to give you optimum water. I would use the drive pickup for the intercooler and the transom pickup for the engine. Teague makes a real slick adjustable transom pickup for notched transoms. Your really taking a risk without intercooler strainers. Some people who boat in pristine water get away with it. To meet USCG regs. you must have cutoffs on all incoming water inlets. Pressure relief valves and water pressure guages need to be used. You can use temporary guages for the intercoolers. Your 2 stage water pumps are nice and you could still use them if you want but the stock merc. hp pumps will do nicely if you want to sell them and recoup. some of the money to go toward the other things you'll need. It seems like a lot, but not that bad and just some testing to get water pressures right.
thanks for the info so far guys keep it coming, asked dustin about sand strainers on the innercooler, he told me not to use them, said it would slow the flow for the cooler to much....Deep haven't been to Raystown sinces the late 80s, i guess its changed a lot, thought about running up there this summer....
