What blocks do I have in '93 Fountain? >
Old 02-03-2013 | 09:04 PM
Default What blocks do I have in '93 Fountain?
I have a 1993 Fountain Lightning with stock powered Merc. 502's. What Gen. Block would these motors be?
ruepappy is offline
Old 02-03-2013 | 09:12 PM
Default fixx
if stock power their gen 5's or V and the timing cover wuld be steel..if they were changed the timing cover would be plastic and those would be gen 6..both 6 and 6 use the same internals except for internal valve trane,,5 is hyd flat tappet cam and liftersand 6 is hyd roller cam and lifters...1995 is the cut off date,,so a 95 boat could have either engine..
FIXX is offline
Old 02-03-2013 | 09:46 PM
Fixx is right. 1993 should be Gen V. Timing cover will tell the story.
I think some early 90-92 era 502 blocks were actually Mark IV bowtie blocks. Even the 502 mags.
MILD THUNDER is offline
Old 02-04-2013 | 12:52 AM
It should be a Gen V. If it does not have a fuel pump mount on the engine block then its is a Gen V.
If it has the fuel pump mounting spot on the block, then its a Mark IV.
Griff is offline
Old 02-04-2013 | 11:22 AM
My '93 has 5's
Flyin-Bryan is offline
Old 02-04-2013 | 12:53 PM
rrentsch's Avatar
Registered User
Dose the plastic timing chain cover also apply to 2000 500efi's
rrentsch is offline
Old 02-04-2013 | 05:49 PM
or a bowtie block
ye,all gen 6 has plastic timing cover..
FIXX is offline
Old 02-04-2013 | 07:14 PM
It's actually cast aluminum..
HaxbySpeed is offline
Old 02-04-2013 | 07:23 PM
Default fixx
the canidian ones are lol
FIXX is offline
Old 02-04-2013 | 07:24 PM
Lmao!
