Quick Cuestion ---Kill Switch >
Old 07-19-2002 | 12:45 PM
klmken's Avatar
Default Quick Cuestion ---Kill Switch
Where does the kill switch connect to on the coil + or - ? I can't seem to find the answer in my merc manual.
Thanks,
Ken
klmken is offline
Old 07-19-2002 | 01:26 PM
Official OSO boat whore
It wouldn't matter. An open circuit in either one will shut the coil down. That said, my preference is for the + side as that's where most people would associate it.
Cord is offline
Old 07-19-2002 | 08:19 PM
Vinny P's Avatar
I hate the winter!!
The kill switch cuts out the ignition circuit. That means that it cuts out the positive wire to the coil, pin #5 (purple wire ) in your main connector. You should not cut the negative wire, that wire is the trigger wire from the ignition control module.
Vinny P is offline
Old 07-19-2002 | 11:35 PM
Audiofn's Avatar
Charter Member #232
There are a few ways to skin this cat. One way is to "open the positive when you pull the switch cover off. The other way is the other wire that closes when you pull the cap off. This one goes to ground on the coil. with the other end going to coil. If the cap is off there can be no pulse to the coil and it also kills the engine.
Jon
Put your best foot forward!
Audiofn is offline
Fenderjack
0
08-30-2007 03:25 PM
BLAZE
Boating Safety
1
07-10-2007 09:56 AM
Hang Time 27
12-29-2003 10:10 PM
dyno
07-25-2002 07:14 AM
sheikman
1
05-27-2002 09:45 AM
