Mounting brackets for K Planes hydraulic pumps
Can anyone tell me if the mounting brackets that bolt to the stringers or transom for the Merc Trim pump are the same for merc K Planes hydraulic pumps.
Thanks.
Thanks.
There are 2 bracket types, the older style has a bolt you can remove to undo the mating brackets and the pump can be lifted upward. The new style is a solid aluinum bracket with a stainless steel retaining bracket. In the newer style you have to unbolt the entire bracket to get the pump off of the stringer.
Thanks, Barry
Driver - High's Fuel Your Journey Cigarette Racing Team #598
Thanks, Barry
Many thanks, I appreciate the information.
SJ.
