vapor separator issues
There is a relay in the wiring harness that turns the pump on and off. If the pump is running intermittently, they you prob. have a relay going bad. Try jumping the pump directly as mentioned and see if it runs. If it does, then with the pump still unplugged, put a volt meter or test light in the power lead going to the pump and turn the key on. If it doesn't show +12v, then check the relay. You should be able to hear it clicking when the key is turned on.
Eddie
Eddie
