Stereo question >
Stereo question
Stereo question
Old 02-19-2013 | 02:53 AM
Default Stereo question
Looking at the Sony dsmxs60 head unit. On fleabay for 235 comes with wired remote. My question is if I bought a second wired remote can I wire both into one head unit. Not sure if the regular remote will work from helm with radio in cabin and I want one out by swim platform. Ultimately I may need 2 wired remotes. Never had a head unit with a wired remote so my knowledge here is limited.
Thanks for any responses.
Crude Intentions is offline
Old 02-19-2013 | 05:42 AM
On my clarion they make a splitter to run 2
Drock78 is offline
Old 02-19-2013 | 06:01 AM
Thanks Drock. After reading your response an leaning on my old friend google I found Sony does the same thing with y adapters. Problem solved!!
Old 02-19-2013 | 09:38 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
My Sony just uses standard Y's I bought from RS. I had 2 wired remotes, dash and transom. The dash had a display which used a sep wire lead for that feature, but the operations wire controlled by standard phono cable
US1 Fountain is offline
Old 02-19-2013 | 08:04 PM
Mike.....
Which remote? There are two for marine application, one has a display, one does not.
The one without needs only a 3.5mm y. The one with needs a 3.5mm AND a unlink y.
Either way, I have the parts here in the garage....as I should...seeing as how I designed them
commandersander is offline
