anyone have an '82 40' Excalibur Hawk? >
Old 02-25-2013 | 07:47 AM
whiskeyhangover's Avatar
Default anyone have an '82 40' Excalibur Hawk?
Does anyone out there have one of these boats? We are in
the process of bringing the one I have back to life and running
into some problems... thanks!
whiskeyhangover is offline
Old 02-25-2013 | 08:07 AM
PM Jamie.. lilred, see if he wants to part with his... sweet boat
adk61 is offline
Old 02-25-2013 | 08:24 AM
ok.... we just needed to know where the fresh water hold tank is and the best way to get to it. The line that feeds the sink is clogged up and a fish tape won't unclog it so we need to get to it. We believe it's underneath the teak wood floor and need to know a good way to pull that up as well without destroying it.
Old 02-25-2013 | 09:04 AM
My cabin has been completely reconfigured, and there's no longer a sink. But I can do some digging today and let you know the best way to get to the water tank. Btw, don't just reach up and put fuel in the boat at a gas station..... Make sure the nozzle is in the fuel fill not water..... Doh!!!
Unlimited jd is offline
Old 02-25-2013 | 10:21 AM
I had a 82 hawk. I don't remember where the water tank was for the life of me. If indeed it is under the cockpit teak floor, Id probably get another tank and mount it somewhere else rather than pulling the floor up. That would be a project.
Is there water in it now? Maybe you can try putting some compressed air back into the line to break the clog free?
MILD THUNDER is offline
Old 02-25-2013 | 10:52 AM
ok lil red any help would be appreciated!
mild thunder that's a good idea, we'll try that.
Old 02-25-2013 | 06:18 PM
i used a pressure washer to unclog them,,works good with the million little air bubbles to wash the line out..first check the filter at the pump,,they get clogged with mold!
FIXX is offline
Old 02-25-2013 | 07:04 PM
Good new is I was able to follow the full hose most of the way down. Bad news I lost it when it went under the cockpit floor..... So yep tank is under the floor
Old 02-26-2013 | 01:05 PM
that's what I was afaid of... I woyld lie to get to it to see if it's plastic
or metal, because if it's plastic its probably no good now and it need
to be replaced...
