Inconel exhaust valves >
Old 02-28-2013 | 07:07 PM
Default Inconel exhaust valves
Ok why ? Everyone said must have inconel exhaust valves . This is a 750 hp blower motor .
kennyd is offline
Old 02-28-2013 | 07:31 PM
Because Marine Engines Stay at full throttle for extended periods, the exhaust valves are subjected to very high EGTs. Standard valves cant take the heat. Recommend in just about all marine applications, and especially forced induction stuff.
MILD THUNDER is offline
Old 02-28-2013 | 07:32 PM
because the load on a marine engines causes the exhaust valves to get much hotter than a car engine,espically a supercharged deal,you dont want to tulip the valves.
mike tkach is offline
Old 02-28-2013 | 09:49 PM
Full Force's Avatar
Because if you don't lifes gonna suck bad one day... I was on the edge of needing them at 400 hp... guess what.. I lost... better to spend the 400 now then the much more redoing engine, luckily I build mine myself or it woulda cost me tons more...
Full Force is offline
Old 02-28-2013 | 10:54 PM
OUCH,thats why you need inconal exhaust valves!
Old 03-01-2013 | 06:05 AM
Full Force's Avatar
yes, and when a fuel filter gets clogged up with chit because a boat was not ran hard ever then leans engine out real bad, the inconel saved the day!! at same time not even Dean Gellner ever saw a Inconel valve do this... I cat believe it didnt break...btw.. this IS inconel valve...
Old 03-01-2013 | 06:19 AM
Definitely not the place to save a few bucks. Inconel is a proprietary alloy that is extremely corrosion resistant and very tough. Quite difficult to machine. As said above, the exhaust valves in a marine engine experience extreme heat cycles due to the loads and the potential shock from some cold water.
Louie is offline
Old 03-01-2013 | 07:39 AM
That's the other reason....cold water shock. Unless you are running completely dry tailpipes, then there is always water vapor flying around in the exhaust. All it takes is a few drops of that cold water hitting a 1500* exhaust valve, that isn't Inconel, and you are in for a bad day.
Eddie
Young Performance is offline
Old 03-01-2013 | 08:50 AM
ordered Inconel ..... thanks another 800 in parts
kennyd is offline
Old 03-01-2013 | 08:59 AM
800. now or 8000. later,you just saved 7200. bucks.
