Muffs ob dual water pickup bravo 1 >
Old 03-08-2013 | 05:08 AM
Default Muffs ob dual water pickup bravo 1
How do you block off the nose pickup on a dual water pickup Bravo x so I can use the muffs
Scarab29 is offline
Old 03-08-2013 | 05:34 AM
You shouldn't have to, after you start the engine the suction from the sea pump will take over and all water from the muffs will be drawn in
4bus is offline
Old 03-08-2013 | 05:40 AM
If I don't hold my hand over the nose it picks up very little water.. I put new pumps on this winter maybe that will make the differance .. Thanks
Scarab29 is offline
Old 03-08-2013 | 05:42 AM
I have put a piece of duct tape over it before
Drock78 is offline
Old 03-08-2013 | 07:43 AM
GAZ
This is what I used to do also. Things are changing with the new SCX drive!
GAZ is offline
Old 03-08-2013 | 08:44 AM
bcfountain's Avatar
Registered User
thats also what i use,,,,,masking tape,,metal tape,,,any tape i can find at the moment.jus dont forget to take it off before you splash your boat.
bcfountain is offline
Old 03-09-2013 | 09:20 AM
This works great on mine.
http://www.ebay.com/itm/QUICKSILVER-...-/150880121907
M39976 is offline
