Peppers To Run Superboat Class With Mercury Racing 525 Engines >
Old 03-14-2013 | 09:00 AM
Correspondent
Correspondent
Default Peppers To Run Superboat Class With Mercury Racing 525 Engines
With a lot less power, Stancombe plans to run at least ten races in Superboat class this year, http://speedonthewater.com/in-the-ne...5-engines.html.
Matt Trulio is offline
Old 03-14-2013 | 09:11 AM
LubeJobs42's Avatar
That's great! Hopefully they can find a better throttleman then the old one!
LubeJobs42 is offline
Old 03-14-2013 | 09:42 AM
Wahoo ATV's Avatar
Racer
Good Luck to em
Wahoo ATV is offline
Old 03-14-2013 | 09:47 AM
Big Time's Avatar
I like the fact that there are more boats in the 750 class, but I really thought that the SuperCat Light class was a great class, and for a while there was a pretty decent # of boats. It's too bad SBI couldn't keep that class together. I wish them (Peppers) luck in this new class.
Big Time is offline
Old 03-14-2013 | 10:59 AM
Hope they do well! Mike is a good guy
precisiondetails is offline
Old 03-14-2013 | 11:09 AM
glassdave's Avatar
Neno the mind boggler
be good to see Mikey and the crew out there again. The fellas on Jay street in St Clair miss him
08 OPA High Points Champion
glassdave is offline
Old 03-14-2013 | 11:20 AM
matt, wish you and your fellow "journalists" would ask alot more questions. and do a little fact checking.
just from what i've read all 3 classes are gone - 525 lite, 750 better known as supercat and 850 merc atleast in SBI.
they consilidated all into "700"-ish HP class. basically taking the compression out of the 750 motors and lowering the RPM.
as for drives, all the classes ran #6 merc's, so other than a few having to do gear changes no big deal.
same with props, actually the 525 guys had to have a bigger selection since i think they allowed different gear ratios. were as the old 750 was limited to 1.61 only.
ever been around teague while testing ????? he had 2 guys with hand carts as prop-toters. and again the old 750 guys were limited to 34 pitch so actually alittle less of a selection.
the 160k in cost i think is slightly exxageratred by about 100k plus add in selling the 525s.
skaterdave is offline
Old 03-14-2013 | 11:22 AM
TeamSaris's Avatar
Driver-441
Racer
Thought that myself.
Either way, Good luck Mike!!!!!!!
TeamSaris is offline
Old 03-14-2013 | 11:28 AM
then you got the whole issue if they're running legal 525's. with a little work could bring them up to about 630. run the boat under weight and should be able to run with em
Old 03-14-2013 | 12:06 PM
Big Time's Avatar
Not all the racers in the Cat Lite ran 6's. Some of them ran XR's. I imagine Pepper's is running with XR's at the moment? I can see purchasing 2 new 6's (with extra parts), two new engines (with extra parts), a couple sets of new props and all of the cost associated with re-rigging the boat would get you up over the 100k mark real easy.... But you are right, net they could probably come in well under that 160k total if they can sell off some of the old equipment.
Big Time is offline
