Need urgent help from an expert >
Old 03-15-2013 | 10:57 AM
Default Need urgent help from an expert
Hi,
I am closing to buy a 2002 Stingray with a Mercrusier 6.2 Liters.
About 500 hours.
Do I have to be worry for anything with the engine?
Normal maintenance done regularly.
Thank for your kind, help
Andrea
adanuso is offline
Old 03-15-2013 | 11:10 AM
Ted G's Avatar
At that amount of hours I would request a compression test be done on the engine, that will tell it's relative "health". It may cost a hundred dollars or so but could save thousands. Also all fluids including the drive should be checked by a qualified technician, that will show a lot.
www.cbpba.com
Ted G is offline
Old 03-15-2013 | 01:47 PM
Default Thanks
Thank you I really appreciate
Andrea
adanuso is offline
Old 03-15-2013 | 02:03 PM
I honestly don't know much about the ''stingray'' boats, but for some reason in my head Im thinking ''poor quality''. I could be totally wrong, maybe I misread something in the past, but might be worth asking or researching that brand.
MILD THUNDER is offline
Old 03-15-2013 | 02:48 PM
I had a 230 sx, a lot of performance for the money, but the build quality was about as bad as my hawk. EVERYTHING fell apart when it was a little rough. Great inland lake or pond boat, not a bay or ocean boat by any means.
Unlimited jd is offline
Old 03-15-2013 | 10:05 PM
A compression test and drive check are certainly good advice.
If it were me, I would also ask the tech how much to scope the camshaft. It never lies.
Cheers
Element 13 is offline
Old 03-15-2013 | 10:22 PM
I know nothing about the boat but 500 hours on 6.2s is nothing.
Wes Burmark is offline
Old 03-15-2013 | 10:24 PM
Expensive Date's Avatar
Salt water? its due for manifolds risers and possibly heads. Fresh you are fine if it checks out.
Expensive Date is offline
Old 03-15-2013 | 11:15 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Look for spider cracks on the bottom of the hull . Climb under and have a good close look .
the deep is offline
Old 03-15-2013 | 11:38 PM
Exclamation
Also look for spider and spider monkeys in the cuddy.. its a common problem
ICDEDPPL is offline
