Is this piston usable? >
Old 03-17-2013 | 10:19 PM
Default Is this piston usable?
Planning on doing 540's in the next year or two so just trying to put together current engines on a budget. The cylinder has pitting in it due to a poorly installed intake manifold gasket that not only allowed water into engine but also had a 1/2" split in the #7 cyl. I'm planning on having that cylinder sleeved this week but was hoping I could still use this piston. It has small pitting likely due to the water that sat in it. These are 60 over JE's. Will be using all new rings.
Attached Thumbnails Is this piston usable?-photo-1.jpg   Is this piston usable?-photo-2.jpg
prostock85 is offline
Old 03-17-2013 | 10:31 PM
I personally wouldn't use it. You can just buy 1 piston
MILD THUNDER is offline
Old 03-17-2013 | 10:37 PM
Thats what I was thinking, my only problem is I don't know exactly what I have. I know its 4.530" and has a 6.135 rod. Hopefully thats enough for JE to get me one. Its pre 04 so there are no markings except casting number.
Old 03-18-2013 | 12:04 AM
Default fixx
looks like salt water dammage,,like mentioned i would not use it..if they are je castings inside then sent it to them and they can match it..
FIXX is offline
Old 03-18-2013 | 12:07 AM
Correct me if i'm wrong but shouldn't he weigh the old one vs the new one and have them matched in weight?
sonicss42 is offline
Old 03-18-2013 | 12:11 AM
Default fixx
yes,,one reason to send it in if theirs no part number to go by..
FIXX is offline
Old 03-18-2013 | 02:15 AM
Not with the side skirt being damaged. I would be getting a new piston.
f_inscreenname is offline
Old 03-18-2013 | 03:52 AM
two questions.....
1) how much is a new piston???
2) how much is it going to cost to rebuild the motor if the piston comes apart at WOT and the rod is bouncing around???
phragle is offline
Old 03-18-2013 | 05:54 AM
As mentioned, replace the piston. Based on the specs you gave, the piston should have a compression height of 1.645 (9.8 block, 6.135 rod). It's just a standard JE flat top in 4.530 bore. Order part # 257985.
Eddie
Young Performance is offline
Old 03-18-2013 | 07:46 AM
I'd use that piston .Saw it through the wrist pin hole and make an ashtray
motor is offline
