I figured my problem, man I am getting good at this! Need to know why this happened. >
Old 07-22-2002 | 06:27 PM
Default I figured my problem, man I am getting good at this! Need to know why this happened.
After a long run on Sun I docked the boat. About 45 min. later I went to load onto the trailer. The port motor would not turn over. All I would hear is a click....and that was it. Well, today, after pulling plugs and trying to see if the motor would turn over, with the coil wire off, I noticed the Procharger torquing over each time I turned the key. I took the belt off and could not turn the pully on the supercharger. Then I saw that the pully had somehow been pulled in towards the housing and wore a groove in the pully and wore away the edge of the housing. The pully was so tight that I had to use a bearing puller to loosen it. The bearings were binding up but then spun freely. I can get the bearings locally but I know Procharger probably will not sell me a new front housing.
Does this sound normal for a bearing failure to actually pull the pully in? Or did the bolt on the pully somehow grab and over tighten?
Pure Energy is offline
Old 07-22-2002 | 06:33 PM
thunderdan's Avatar
Ken,
sorry do not know the answer to your question, but did you go up to AC on Sat or Sunday with kenp and the others from n jersey? I was there on Sat but spend my day Sunday working around the house.
thunderdan is offline
Old 07-22-2002 | 06:50 PM
Hey Dan,
How the new ride? No, I did not go to A/C. Spent the day raging on the Hudson. It got rough too Fun ride.
cloke
02-23-2008 12:17 AM
blewbyyou1970
Classic Offshore
5
05-25-2007 07:41 AM
sakoutis3
09-27-2006 05:24 AM
Team V
05-17-2002 08:25 AM
