How to wire in a trim limit switch >
Old 03-25-2013 | 07:28 PM
Default How to wire in a trim limit switch
Howdy,
I'd like to wire-in a trim limit switch on a boat that doesn't currently use one. The Bravo on my boat doesn't have a 'trailer' button, trim only. However, due to the external steering cap and the low swimdeck if one isn't paying attention he may accidentally stuff the drive up into said platform. Not cool.
My plan is to adjust it to kill the up trim shortly before it collides with the swim deck.
Also, how hard is it to add a mechanical trim indicator? I'm fairly savvy with tools, I keep a small machine shop as a hobby, but I'm looking if there are any pitfalls.
Cole2534 is offline
Old 03-25-2013 | 09:57 PM
I assume something is wrong with your stock trims sender and limit switch .Or is it a high perf without them. People will commonly bypass limit switch instead of repair it..
It's easy to install mechanical sender if that's what you need .nothing but $
motor is offline
Old 03-25-2013 | 11:57 PM
i didny look but knew it was a fountain..like mentioned most likely bypassed..look at the trim pump,their are bullett connectors going to it from the drive area,,look to see if they are connected..if you have a trim gauge then you will have the sender and it just may need to be hooked up or it is hooked up and may just need to be adjusted..as for external trim gauge look at eddiemarine.com they have a feew or go to the vender list on the left side of this page and pick one and start calling for pricing.
FIXX is offline
Old 03-26-2013 | 06:26 AM
Mercury sells spacers that go inside your rams so it limits how far the drive can go up. Easy to do I had to do this on mine when I put on my new drive!
KWright is offline
Old 03-26-2013 | 06:51 AM
I'm fairly certain this is what's happened. And yes, I do have a failed trim gauge or sending unit that I'm looking to replace. But I took the limit switch apart and shined up the contacts, it's so dead simple it's nearly impossible for it to fail.
I'll have a look this weekend. Thanks.
Cole2534 is offline
Old 03-26-2013 | 08:15 AM
We had to do this also. Very simple project
Perlmudder is offline
Old 03-26-2013 | 08:18 AM
GAZ
Can you explain this some more ? Or post a link to the spacer please.
GAZ is offline
Old 03-26-2013 | 08:32 AM
Here ya go
KWright is offline
Old 03-26-2013 | 09:07 AM
That's one way to do it, but I'm going to try the method that doesn't require bleeding cylinders first.
Cole2534 is offline
Old 03-26-2013 | 10:30 AM
I had a solinoid stick and drove the drive into the swim platform hearing your gimbal crack is a sound you really don't want to hear! Trust me.
KWright is offline
