Merc 600's info? >
Merc 600's info?
Merc 600's info?
Old 07-23-2002 | 11:40 AM
jawbreakerkid's Avatar
Question Merc 600's info?
does anyone have any tech info on the merc 600's? what block, blower, carbs, boost, etc.? what kind of hp/torque at what rpm ranges are they producing? what kind of experiences have you had with these motors? how many normal hours can be expected out of them before a rebuild?
any info or links to info would be appreciated.
thanks in advance....
chad
jawbreakerkid is offline
Old 07-23-2002 | 12:13 PM
Brad Perry
I think they were 540ci with B&M 420s.
Old 07-23-2002 | 12:57 PM
thanks for the info, brad.
anyone else?????
chad
Old 07-23-2002 | 01:03 PM
IRONMAN's Avatar
They are 502's with the megablower, dual holley 750's and cmi exhaust.
IRONMAN is offline
Old 07-23-2002 | 01:17 PM
did they all have dual 750's on them? the picture i have of the motors sitting in a cig do not have dual 750's on them....
Old 07-23-2002 | 02:13 PM
Brad Perry
Those are also not B&M 420 megablowers either.
Old 07-23-2002 | 04:50 PM
later's Avatar
JBK 600'S
the 600's were 502 ci motors with 7.5 compression used the B&M 420 megablower they were rated at 550 at the prop, rpm range was 4800-5200. they would make more power if you ran them with more rpm and boost which i believe in stock trim they ran approx. 5lbs of boost. with a minumum octane of 91 and 93 the perfered choice. they only came as a bobtail and were rough on bravo's.
later is offline
Old 07-23-2002 | 05:09 PM
later- thanks for the info! with only 5lbs of boost, i would think the reliability/longevity would be decent. either way, with 230 original hours, i'm still looking at a rebuild in the very near future.
are you going to be at the lake this weekend? i'll probably be down, but it will be a working weekend for me. i'm finishing moving into the new place and then probably cleaning on the boat, changing oil, etc.
thanks again,
chad
Old 07-24-2002 | 01:05 PM
later's Avatar
JBK
i take it your looking at a 38 cig with 600's
I would think that at 230hrs you wouldnt get to many moer hrs before rebuilds. although i have read were some of the blower motors go into the 400hrs im sure there pretty tired. i will be down this weekend having a relaxing weekend. had all my guy's and their wifes that work for me down for a bbq last weekend about 26 people and i was wopped entertaining and all (hard work) making sure everyone is having a good time. ill be piddling this weekend wax the boat etc. hopefuly your moved into your new place and have found a place for everything by now are found everything sometimes thats a chore unpacking and all. ill look for you on the water and if your up my way stop by and ill by you a drink.
later is offline
Old 07-24-2002 | 01:16 PM
yep, i've always had a thing for that boat. i used to see it flying up and down the lake when Brian Foster owned it. i'm actually looking for a late model T/S, but old memories die hard...LOL.
i'll look you up if i'm up at your end of the lake. thanks again!
chad
