454 interchange question.
Old 04-10-2013 | 08:05 PM
Default 454 interchange question.
Going to look at a motor saturday that is in a TRS boat. I have a bravo. I know will have to swap bellhousings.Anything else different?? Is the coupler the same? Motor was supposedly rebuilt 4 years ago but never ran, would this present any issues?
phragle is offline
Old 04-10-2013 | 08:10 PM
the coupler is different,does the engine you are looking at have a flywheel?
mike tkach is offline
Old 04-10-2013 | 08:48 PM
havent looked at it yet. its supposed to be complete and still in a boat.
phragle is offline
Old 04-10-2013 | 09:02 PM
coupler is totally different .the flywheel i would keep with the motor . however the ring gear is going to be on the wrong side. the flywheel will already be cut on the side you need to use its a matter of pressing it off and back on the other side .it can be heated with a torch and simply knocked off and back on the opp side takes no more than 10 min
smokin' gun is offline
Old 04-10-2013 | 09:12 PM
as long as both engines are the same generation the flywheel can be switched,the trs engine is a mark 4,what year is the bravo engine?
Old 04-10-2013 | 09:14 PM
My boat came engineless, but with bravo gimbleand drive. I have the bravo bell housing and coupler already. Thanks for the info guys!!
phragle is offline
Old 04-10-2013 | 10:27 PM
Default TRS engine
The ring gear on the flywheel will only be wrong if the engine has a borg warner transmission with the rear mounted starter. If it has a Merc II transmision it will be fine where it is.
MASOMAN is offline
