Rusteing of painted steel trailers
Is it true that if you boat in salt water/launch your boat from a painted steel trailer 3 or 4 times a year that the trailer will rust? So it is adviseable to buy a aluminum or galvanized one. The trailer that I was thinking of buying was a Nordic for a Nordic boat.
Your best bet is Allum. or Galvi for sure. Is that trailer Boxed in? Some of the steel trailers that I have seen like Norts AKA PhantomChaos is boxed in and preasureized. That helps out a lot. The problem with steel boxed in trailers is that they salt water gets on the inside untreated part of the tube. Then starts to rust from the inside out. The outside of the trailer can look great but the inside can be totally waisted. Then you trailer breaks in half. I have seen it happen!!! If you can wash the entire trailer down both inside and out then steel is ok otherwise I would opt for the allum or galvi trailer.
Jon
Jon
Put your best foot forward!
fantastixvoyage
9
09-13-2008 02:22 PM
groundstrike
06-11-2007 06:43 PM
