Multi weight oils. Good info. >
Old 04-20-2013 | 02:34 PM
Default Multi weight oils. Good info.
I have recently been doing a lot of research on engine oils. Ive had to many dock and bar room discussions on oil, and decided to spend some time reading up. We all talk about zinc content, and other minerals and additives, but.....theres more to it than that. During all these late nights of reading and reading, I started noticing something common in all these write up's, that was common.
Its about the use of multi-weight oils. Apparently, in conventional engine oil, in order to develop a multi weight oil, they must use ''Viscosity improvers". Lets take a 20W50 oil for example.
The oil must flow like a 20 weight oil at 0* Fahrenheit , and a 50 weight at 210*. Problem with oil using viscosity improvers, is that they don't do well with heat and or high load/shear situations, and eventually break down. When the oil does break down, it no longer resists thinning at temperature, and therefore that 20w50, may act like a 20w20, 20w30, etc at 210* after a few hours depending on the situation.
Some articles I've read from oil engineers, is that if a multi viscosity oil must be used, try to use one with as little visc improvers as possible. Meaning, a 10w30, or 5w20, will have less than say a 20w50, or 10w40.
With that being said, synthetic multiweight oils do not suffer from this. As the makeup of the oil doesn't need the viscosity improvers like a conventional dino style oil. Probably why you see synthetic 15w50, 5w50, etc. Plus they say the synthetics hold up much better with heat and do not break down as easily.
To sum things up, I have read enough on this subject, to myself go back to using a straight weight conventional, without viscosity improvers. My boat engine oil will never see 0 degrees Fahrenheit, not even 32* Fahrenheit. Most day's im boating the pan temps will be ambient at startup, which should be anywhere from 75-90*. The 20w50 I was using, at those temps, probably isn't flowing like a 20 weight oil anyhow, since it was tested to flow like a 20w at 0 degrees. I know there are a lot of builders out there still recommending straight weight oil for marine engines. I just never knew why they would recommend that.
I am going to attach a couple articles on this, for those who may wish to read for themselves. Grab a cup of coffee or a cold brew and check it out.
Very good read. Covers a ton about oil.
http://hrcak.srce.hr/file/37720
http://www.enginebuildermag.com/Arti..._slippery.aspx
MILD THUNDER is offline
Old 04-20-2013 | 03:42 PM
Mild
As I have said on different oil threads that for the Past 30+ years I have used straight 40 w Racing oil in all my boat motors Most of them Blower motors without any Lower end Failures, the boat I have now is going on it's 14th season this year withoout any oiling problems. So with that said I'm 100% backing your findings with real world results.
Thanks for getting the info out to the members!
abones is offline
Old 04-20-2013 | 04:26 PM
I agree with you on stright weight racing oils for our boats, I use Dino but synthetic is fine if you want to speed the coin.
offshorexcursion is offline
Old 04-20-2013 | 04:36 PM
That's some great information Wild Mulder!
ICDEDPPL is offline
Old 04-20-2013 | 04:54 PM
What oil you gonna run ICPPLSDIKS?
Old 04-20-2013 | 04:57 PM
Originally Posted by abones
Mild
Good stuff buddy. I'd like to see a oil viscosity test done on say a 20w50 at 100* Fahrenheit. We know what it is a 0* and 210*, but what about in the middle?
Old 04-20-2013 | 05:11 PM
The following group of 14 oils are ranked according to their “load carrying capacity/film strength”, or in other words, their “wear protection” performance, at 230*F. The tests were repeated multiple times for each oil, and then those results were averaged to arrive at the final psi numbers shown below. And every single oil was tested EXACTLY THE SAME.
1. 10W30 Valvoline NSL (Not Street Legal) Conventional Racing Oil = 103,846 psi
zinc = 1669 ppm
total detergent = 1618 ppm
detergent ppm/zinc ppm ratio = 1.0
NOTE: Due to its very low TBN value, this oil is only suitable for short term racing use, and is not suitable for street use.
2. 10W30 Valvoline VR1 Conventional Racing Oil (silver bottle) = 103,505 psi
(.3% below no.1)
zinc = 1472 ppm
total detergent = 2787 ppm
detergent ppm/zinc ppm ratio = 1.9
3. 10W30 Valvoline VR1 Synthetic Racing Oil, API SL (black bottle) = 101,139 psi
(2.6% below no.1)
zinc = 1180 ppm
total detergent = 2683 ppm
4. 10W30 Amsoil Z-Rod Oil = 95,360 psi
(8.2% below no.1)
zinc = 1431 ppm
total detergent = 2927 ppm
detergent ppm/zinc ppm ratio =2.0
5. 10W30 Quaker State Defy, API SL (semi-synthetic) = 90,226 psi
(13.1% below no.1)
zinc = 1221 ppm
total detergent = 2830 ppm
detergent ppm/zinc ppm ratio =2.3
6. 10W30 Joe Gibbs HR4 Hotrod Oil = 86,270 psi
(16.9% below no.1)
zinc = 1247 ppm
total detergent = 3134 ppm
detergent ppm/zinc ppm ratio = 2.5
7. 5W30 Royal Purple XPR (Extreme Performance Racing) = 74,860 psi
(27.9% below no.1)
zinc = 1421 ppm
total detergent = 3050 ppm
detergent ppm/zinc ppm ratio = 2.1
8. 15W40 Farm Rated Heavy Duty Performance Diesel, CI-4, CH-4, CG-4, CF/SL, SJ (conventional) = 73,176 psi
(29.5% below no.1)
zinc = 1325ppm
total detergent = 1593 ppm
detergent ppm/zinc ppm ratio = 1.2
9. 0W30 Brad Penn, Penn Grade 1 (semi-synthetic) = 71,377 psi
(31.3% below no.1)
zinc = 1621 ppm
total detergent = 2939 ppm
detergent ppm/zinc ppm ratio = 1.8
10. 10W30 Brad Penn, Penn Grade 1 (semi-synthetic) = 71,206 psi
(31.4% below no.1)
zinc = 1557 ppm
total detergent = 3173 ppm
detergent ppm/zinc ppm ratio = 2.0
11. 15W50 Mobil 1, API SN = 70,235 psi
(32.4% below no.1)
zinc = 1133 ppm
total detergent = 1437 ppm
detergent ppm/zinc ppm ratio = 1.3
12. 10W30 Royal Purple HPS (High Performance Street) = 66,211 psi
(36.2% below no.1)
zinc = 1774 ppm
total detergent = 3676 ppm
13. 10W40 Valvoline 4 Stroke Motorcycle Oil conventional, API SJ = 65,553 psi
(36.9% below no.1)
zinc = 1154 ppm
total detergent = 1999 ppm
detergent ppm/zinc ppm ratio =1.1
14. Royal Purple 10W30 Break-In Oil conventional = 62,931 psi
(39.4% below no.1)
zinc = 1170 ppm
total detergent = 3184 ppm
detergent ppm/zinc ppm ratio = 2.7
Now, in the interest of full disclosure, let’s compare the new Defy motor oil to “ALL” of the other 47 oils that I have in my database, and see how it ranks against them all.
*** The higher the psi result, the higher the “Load carrying capacity/Film strength”, and the better the oil is at preventing wear.
*** All oils were tested at 230* F (representative of actual running temperature).
*** Multiple tests were performed on each oil, and those results were averaged to arrive at each oil's final value shown below.
*** Test Result differences between oils of less than 10%, are not significant, and oils within that range can be considered approximately equivalent.
*** All oil bottles were thoroughly shaken before the samples were taken. This ensured that all the additive package components were distributed uniformly throughout all the oil in the bottle, and not settled to the bottom.
*** All oils are full synthetic unless otherwise specified.
*** All oils are suitable for street use unless otherwise specified.
Oil categories:
*** Over 90,000 psi = OUTSTANDING protection
*** 75,000 to 90,000 psi = GOOD protection
*** 60,000 to 75,000 psi = MODEST protection
*** Below 60,000 psi = UNDESIREABLE
********** OUTSTANDING PROTECTION ************
1. 5W30 Pennzoil Ultra, API SM = 115,612 psi
I have not been able to find this oil with the latest API SN certification. The bottle says, “No leading synthetic oil provides better wear protection”. For once, a product’s hype turns out to be true.
zinc = 806 ppm
phos = 812 ppm
moly = 66 ppm
2. 10W30 Lucas Racing Only = 106,505 psi
zinc = 2642 ppm
phos = 3489 ppm
moly = 1764 ppm
NOTE: This oil is suitable for short term racing use only, and is not suitable for street use.
3. 5W30 Mobil 1, API SN = 105,875 psi
zinc = 801 ppm
phos = 842 ppm
moly = 112 ppm
4. 0W30 Amsoil Signature Series 25,000 miles, API SN = 105,008 psi
zinc = 824 ppm
phos = 960 ppm
moly = 161 ppm
******* 10% below number 1 = 104,051 psi ********
5. 10W30 Valvoline NSL (Not Street Legal) Conventional Racing Oil = 103,846 psi
zinc = 1669 ppm
phos = 1518 ppm
moly = 784 ppm
6. 5W50 Motorcraft, API SN = 103,517 psi
zinc = 606 ppm
phos = 742 ppm
moly = 28 ppm
7. 10W30 Valvoline VR1 Conventional Racing Oil (silver bottle) = 103,505 psi
zinc = 1472 ppm
phos = 1544 ppm
moly = 3 ppm
8. 10W30 Valvoline VR1 Synthetic Racing Oil, API SL (black bottle) = 101,139 psi
zinc = 1180 ppm
phos = 1112 ppm
moly = 162 ppm
9. 5W30 Chevron Supreme conventional, API SN = 100,011 psi
This one only costs $4.29 per quart at the Auto Parts Store where I bought it.
zinc = 1018 ppm
phos = 728 ppm
moly = 161 ppm
10. 5W20 Castrol Edge with Titanium, API SN = 99,983 psi
zinc = 1042 ppm
phos = 857 ppm
moly = 100 ppm
titanium = 49 ppm
11. 20W50 Castrol GTX conventional, API SN = 96,514 psi
zinc = 610 ppm
phos = 754 ppm
moly = 94 ppm
12. 30 wt Red Line Race Oil = 96,470 psi
zinc = 2207 ppm
phos = 2052 ppm
moly = 1235 ppm
13. 0W20 Mobil 1 Advanced Fuel Economy, API SN = 96,364 psi
zinc = 742 ppm
phos = 677 ppm
moly = 81 ppm
14. 5W30 Quaker State Ultimate Durability, API SN = 95,920 psi
zinc = 877 ppm
phos = 921 ppm
moly = 72 ppm
15. 5W30 Castrol Edge with Titanium, API SN = 95,717 psi
zinc = 818 ppm
phos = 883 ppm
moly = 90 ppm
titanium = 44 ppm
16. 10W30 Joe Gibbs XP3 NASCAR Racing Oil = 95,543 psi
zinc = 743 ppm
phos = 802 ppm
moly = 1125 ppm
17. 5W20 Castrol GTX conventional, API SN = 95,543 psi
zinc = TBD
phos = TBD
moly = TBD
NOTE: Oil numbers 16 and 17 were tested weeks apart, but due to the similarities in their wear scar sizes, their averages ended up the same.
18. 5W30 Castrol GTX conventional, API SN = 95,392 psi
zinc = 830 ppm
phos = 791 ppm
moly = 1 ppm
19. 10W30 Amsoil Z-Rod Oil = 95,360 psi
zinc = 1431 ppm
phos = 1441 ppm
moly = 52 ppm
20. 5W30 Valvoline SynPower, API SN = 94,942 psi
zinc = 969 ppm
phos = 761 ppm
moly = 0 ppm
21. 5W30 Valvoline Premium Conventional, API SN = 94,744 psi
zinc = TBD
phos = TBD
moly = TBD
22. 5W20 Mobil 1, API SN = 94,663 psi
zinc = 764 ppm
phos = 698 ppm
moly = 76 ppm
23. 5W20 Valvoline SynPower, API SN = 94,460 psi
zinc = 1045 ppm
phos = 742 ppm
moly = 0 ppm
******** 20% below number 1 = 92,490 psi ********
24. 5W30 Lucas conventional, API SN = 92,073 psi
zinc = 992 ppm
phos = 760 ppm
moly = 0 ppm
25. 5W30 O'Reilly (house brand) conventional, API SN = 91,433 psi
This one only costs $3.99 per quart at the Auto Parts Store where I bought it.
zinc = 863 ppm
phos = 816 ppm
moly = 0 ppm
26. 5W30 Red Line, API SN = 91,028 psi
zinc = TBD
phos = TBD
moly = TBD
27. 5W20 Royal Purple API SN = 90,434 psi
zinc = 964 ppm
phos = 892 ppm
moly = 0 ppm
28. 10W30 Quaker State Defy, API SL (semi-synthetic) = 90,226 psi
zinc = 1221 ppm
phos = 955 ppm
moly = 99 ppm
29. 5W20 Valvoline Premium Conventional, API SN = 90,144 psi
zinc = TBD
phos = TBD
moly = TBD
************ GOOD PROTECTION **********
30. 30 wt Castrol Heavy Duty conventional, API SM = 88,089 psi
zinc = 907 ppm
phos = 829 ppm
moly = 56 ppm
31. 10W30 Joe Gibbs HR4 Hotrod Oil = 86,270 psi
zinc = 1247 ppm
phos = 1137 ppm
moly = 24 ppm
32. 5W20 Pennzoil Ultra, API SM = 86,034 psi
zinc = TBD
phos = TBD
moly = TBD
33. 5W30 Royal Purple API SN = 84,009 psi
zinc = 942 ppm
phos = 817 ppm
moly = 0 ppm
34. 20W50 Royal Purple API SN = 83,487 psi
zinc = 588 ppm
phos = 697 ppm
moly = 0 ppm
35. 20W50 Kendall GT-1 High Performance with liquid titanium, (conventional) API SN = 83,365 psi
zinc = 991 ppm
phos = 1253 ppm
moly = 57 ppm
titanium = 84 ppm
36. 5W30 Mobil 1 Extended Performance 15,000 mile, API SN = 83,263 psi
zinc = 890 ppm
phos = 819 ppm
moly = 104 ppm
37. 0W20 Castrol Edge with Titanium, API SN = 82,867 psi
zinc = TBD
phos = TBD
moly = TBD
******** 30% below number 1 = 80,928 psi ********
38. 5W30 GM's AC Delco dexos 1 (semi-synthetic) API SN = 76,501 psi
zinc = 878 ppm
phos = 758 ppm
moly = 72 ppm
**************** MODEST PROTECTION ************
39. 5W30 Royal Purple XPR (Extreme Performance Racing) = 74,860 psi
zinc = 1421 ppm
phos = 1338 ppm
moly = 204 ppm
NOTE: This particular bottle of oil was just opened, but was out of a 3 ½ year old case.
40. 15W40 Farm Rated Heavy Duty Performance Diesel, CI-4, CH-4, CG-4, CF/SL, SJ (conventional) = 73,176 psi
zinc = 1325ppm
phos = 1234 ppm
moly = 2 ppm
41. Brad Penn, Penn Grade 1 Nitro 70 Racing Oil (semi-synthetic) = 72,003 psi
zinc = TBD
phos = TBD
moly = TBD
42. 0W30 Brad Penn, Penn Grade 1 (semi-synthetic) = 71,377 psi
zinc = 1621 ppm
phos = 1437 ppm
moly = 0 ppm
43. 10W30 Brad Penn, Penn Grade 1 (semi-synthetic) = 71,206 psi
zinc = 1557 ppm
phos = 1651 ppm
moly = 3 ppm
44. 15W50 Mobil 1, API SN = 70,235 psi
zinc = 1,133 ppm
phos = 1,168 ppm
moly = 83 ppm
******** 40% below number 1 = 69,367 psi ********
45. 5W30 Motorcraft, API SN = 68,782 psi
zinc = 796 ppm
phos = 830 ppm
moly = 75 ppm
46. 10W30 Royal Purple HPS (High Performance Street) = 66,211 psi
zinc = 1774 ppm
phos = 1347 ppm
moly = 189 ppm
47. 10W40 Valvoline 4 Stroke Motorcycle Oil conventional, API SJ = 65,553 psi
zinc = 1154 ppm
phos = 1075 ppm
moly = 0 ppm
48. Royal Purple 10W30 Break-In Oil conventional = 62,931 psi
zinc = 1170 ppm
phos = 1039 ppm
moly = 0 ppm
******** 50% below number 1 = 57,806 psi ********
Old 04-20-2013 | 05:50 PM
Interesting.... I always noticed that when running 20w50 after putting a few hours on a fresh oil change the oil pressure at idle after a long run would progressively diminish. Semi synthetics seem to perform better than straight dino and I always assumed this had something to do with viscosity deterioration due to heat. My solution has been to top the oil levels off with Lucas heavy duty oil stabilizer as needed which has worked pretty well for me.
MILD THUNDER great post!
dandercam1 is offline
Old 04-20-2013 | 06:01 PM
Im shocked at how poorly Royal Purple performed
Drock78 is offline
Old 04-20-2013 | 06:02 PM
The idea of relying on additives (visc improvers) to protect and do their job, just scares me. In my particular engines, the idea of 20weight oil at 6000rpm under boost and heat, doesn't excite me. maybe I'll send in a sample of my Brad Penn 20w50 with about 10 hours on it, for a oil analysis to see how it held up viscosity wise.
