Go Back  Offshoreonly.com > Owners Forum > Donzi
38 zr fuel tanks >
38 zr fuel tanks
38 zr fuel tanks
Old 04-22-2013 | 10:27 AM
Default 38 zr fuel tanks
I just purchased a 2007 38 zr. I have looked everywhere and can't find a switch to switch tanks. Do they draw fuel from both tanks or are the connected somehow? Thanks
outlaw25 is offline
Old 04-30-2013 | 06:59 AM
The tanks are not connected from the factory and are matched to respective engines.
IN25Outlaw is offline
Old 04-30-2013 | 07:59 AM
we have a 2008 model and its one tank as far as I can tell. you can fill it from either side of the boat.
It holds around 650 litres of fuel. Not sure if it is a smaller tank because we also have a holding tank for the toilet.
Australia is offline
Old 04-30-2013 | 08:38 AM
Tom A.'s Avatar
Mine is a ZrC and is a little different but I have a tank for each engine and am pretty sure that is how the Zr's were basically set up.
Tom A. is offline
Old 04-30-2013 | 03:06 PM
I have a 35 zr and it only has one tank you can fill from either side.
Donzi Dude is offline
Old 04-30-2013 | 04:30 PM
The early 38zr's were built like the comp with split fuel tanks due to the center stringer and staggered engines. If you have a toggle switch by the fuel gauge to select port or starboard tanks is the easy way to tell.
Boat Boss is offline
Old 04-30-2013 | 06:58 PM
MarkDonzi's Avatar
I have an 05 38ZR with separate tanks for each engine. There is a way you can switch from one to the other with the fuel line valves located on the motorbox bulkhead. I never had a need to do this so I never looked at it very closely. I have a switch on the dash to check the fuel levels in each tank.
MarkDonzi is offline
Old 04-30-2013 | 07:37 PM
25 outlaw to a 38zr!!!! Big step...congrats!!!
tnc110 is offline
Old 05-01-2013 | 05:26 PM
Went from a 25 outlaw to a 33 outlaw then the 38zr.
outlaw25 is offline
