3M compound question
Old 07-24-2002 | 07:38 PM
Pantera1's Avatar
Default 3M compound question
Started buffing out the project boat with 3M super duty rubbing compund..Its working but it seems to be staining the white gel coat a little brownish puke color..Went to 3M website and found Finesse it white paste compound supposed to not stain light colored gel.. My question is if its the same grit or fast cut as the super duty or not ..This things realy oxidized.
Pantera1 is offline
Old 07-24-2002 | 07:48 PM
glassdave's Avatar
Neno the mind boggler
try Ditzlers DRX55, its a fast cut compound and its white in color so it wont stain the gel. if you need a fine compuond use 3M's finnessit fine compound with a wool pad, foam pads dont work to well with gel coat.
glassdave is offline
Old 07-24-2002 | 07:50 PM
glassdave's Avatar
oh yea . . use the wool pad for the DRX55 also
Old 07-24-2002 | 07:53 PM
Steve 1's Avatar
Use Perfect it 111 extra cut with a White wool super buff pad first ! then finess it 11 with a yellow pad higher speed finial !
Best Regards
Steve 1 is offline
Old 07-24-2002 | 07:54 PM
Pantera1's Avatar
I always use shliegler wool pads ..Havnt tried foam yet ..what are they good for? Im not sure where I can get ditzler products around here ..Have you used the 3M finesse it paste compound?
Pantera1 is offline
Old 07-24-2002 | 08:00 PM
Hauling Trash's Avatar
Finesse is very good , Its great on color boats.
Hauling Trash is offline
Old 07-24-2002 | 08:04 PM
Pantera1's Avatar
3M has so many damn compounds ..I just need something fast cut and white ..Thought about wet sanding the whole thing ..its that bad .Now I see they have this premium mold and tooling compound ..supposed to take 600 scratches out .
Pantera1 is offline
Old 07-24-2002 | 08:23 PM
stevejohns
save the foam pad for when you wax it
Old 07-24-2002 | 10:41 PM
liquid asset's Avatar
FINESS IT is not strong enough it is not a compound, 3M fiberglass restorer and wax works best with a machine buffer at 1800 rpm, available at Wal-mart for about 8 bucks
liquid asset is offline
Old 07-25-2002 | 12:01 AM
Audiofn's Avatar
Charter Member #232
Finess it is more of a swirl remover. It will not remove any material. Good luck.
Jon
Put your best foot forward!
Audiofn is offline
