Oil pan fitting 7.4
Old 04-27-2013 | 01:29 PM
Default Oil pan fitting 7.4
I have a 88 7.4 putting back together after a couple years and on the oil pan there is a drain plug and the otherside has a brass fitting for like a oil cooler line but can't figure what goes there . Thank you
Smithelectric is offline
Old 04-27-2013 | 06:58 PM
fireboatpilot's Avatar
RIPSTA Racing Team
Might have been for a line to an oil change pump or drain hose to the garboard plug? What size line/fitting we talking about?
fireboatpilot is offline
Old 04-28-2013 | 09:44 PM
Oil drain
f_inscreenname is offline
Old 04-29-2013 | 01:37 AM
The second threaded hole can be used for an oil temp sender or just plugged with a brass pipe plug.
Griff is offline
Old 04-30-2013 | 07:51 PM
its for the dip stick
