flywheel question."help"
The flywheel is the same, however the starter ring gear will be on the wrong side off the wheel. A machine shop can mill the flywheel and move the ring to the side if the flywheel you need it.
The flywheel that belongs to the engine should stay with the engine if possible. If you have an engine without a flywheel you need to figure out if the engine is internally or externally balanced before just throwing a wheel on it. A mistake here will be catastrophic.
I all depends on if it was used with a top mount starter or bottom mount. Some TRS's use bottom block mount starters which is what a Bravo would use.
Also, one thing to note is you can't use a Gen V or Gen VI flywheel on a MK IV, I don't know which motor you have, but I ran into this when I was doing my motors. Something to do with the counter weight.
If you are running a 168 tooth flywheel, with a bottom mount staggered mount starter the ring gear on the flywheel must be on the block side, if rear mount starter ring gear on back it has to be a 168 tooth for rear mount. If you have a Bravo flywheel and are trying to use a mark IV flywheel, I think the counter weight difference is about 65-70 grams.
Did you replace the starter, what has changed from what was there before?
Took every ones advice, I pulled the flywheels and removed the ring gears. I had to mill down the back side do to a lip but putting the motors back in now...
Thanks for the help guys
