What are the Standard Specs for Hp500 Cylinder Heads >
Old 05-01-2013 | 11:51 AM
Default What are the Standard Specs for Hp500 Cylinder Heads
Rectangular Port GM Part No.:
Combustion Chamber Volume (cc):
Intake Runner Volume (cc):
Exhaust Runner Volume (cc):
Intake Valve Diameter (in):
Exhaust Valve Diameter (in):
Seahawk 2000 is offline
Old 05-01-2013 | 12:13 PM
http://www.offshoreonly.com/forums/g...ine-specs.html
mr3dman is offline
Old 05-01-2013 | 06:06 PM
mcollinstn's Avatar
They're GM 088 heads - you can find tons of info regarding post sizes and flow numbers on the web.
118-120cc chambers.
2.18/1.88 valves.
Carbed HP500's used Manley Extreme Duty exhausts.
mcollinstn is offline
Old 05-01-2013 | 10:18 PM
118-120cc chambers.
2.18/1.88 valves.
GM doesn't make that casting number anymore. What casting number is on the newer moters that replaces it.
Old 05-01-2013 | 10:46 PM
I thought there were 2 different versions of the 088 heads. The 454/502 Mags have 2.19/1.88 and the 500 hp, 500 efi, 575 Sci, etc used a 2.250/1.88 combo???
Eddie
Young Performance is offline
Old 05-01-2013 | 10:47 PM
If you are looking for some 088 heads, give me a shout. I have quite a few sets that we can freshen for you. Or, you can buy them as is.
Eddie
Old 05-02-2013 | 06:30 AM
Eddie
Maybe Mercury racing installed larger intake valves on the high perf engines?
I remember in a old service manual, the old 454/370HP,400hp had a standard bbc rect port head pretty much nothing fancy done to the head. But if you were a big spender, and got the 440HP, or 460HP cyclone engines, you got a multi angle valve job and some other stuff done to the heads, I cant remember.
MILD THUNDER is offline
Old 05-02-2013 | 11:18 AM
rmbuilder's Avatar
MarineKinetics
Seahawk,
Rectangular Port GM Part No.: Casting # / Part#
6272990 / 6260482 or 14096188 Original LS-7/LS-7 Open Chamber Designed for the MK IV block
140970088 / 14096802 Service replacement head for the Gen V block
12562925 / 12562934 Service replacement head for Gen V / VI block with 7/16 accessory holes
12562926 / 12562934 Service replacement head for Gen V / VI block with 3/8 accessory holes
The last two are current working part numbers. All heads from GM have the 2.180”/2.190” intake valve
Verify block compatibility
118cc
325cc/318cc
125cc
2.180”/2.190” 3/8” Valve
1.880” 3/8” Valve
26º Intake valve
17º Exhaust valve
4 º Splay
All heads share the same basic port architecture and combustion chamber design. The is no significant performance differential between the heads.
Bob
rmbuilder is offline
Old 05-02-2013 | 02:09 PM
Originally Posted by rmbuilder
Seahawk,
118cc
325cc/318cc
125cc
1.880” 3/8” Valve
26º Intake valve
17º Exhaust valve
4 º Splay
Bob
Thank you Bob
Old 05-02-2013 | 08:59 PM
Wobble's Avatar
SORE MEMBER
Thank you Bob
WOW I see Bob is still giving good Head......
information
What would this place be with out him
Wobble is offline
