Adding fuel tanks?????
Old 07-25-2002 | 12:38 PM
ssherman
Default Adding fuel tanks?????
What is the safest and best way to add additional fuel storage?
I have tanks in the belly now.
The boat is a 99 32 active thunder V-bottom
I would like to ad about anouther 50-75 gallons of capacity for some extended range cruising.
I though a tank on each side in the rear?
Old 07-25-2002 | 12:56 PM
Shane
West marine sells aluminum and plastic tanks in a variety of sizes and shapes, including saddle tanks. If you have room forward of your motors on each side, I'm sure they could be mounted with a little glass work.
BTW, forget the electric tank selector valves. I've had a couple different types fail. Use the old fashion mechanical selector valve.
Also, I think there's an article on yachtsurvey.com that talks about correct fuel tank mounting.
My $0.02
Gary
Gary Anderson is offline
Old 07-25-2002 | 01:12 PM
Mike J
I think your first call
should be to IMCO who makes Alum. Tanks...
909-592-6162 ask for fred.
second would be Fuel-Safe
which is a soft bladder
type and they are Bend OR.
www.fuelsafe.com.
I also have 2 sets of side
tanks that were never used
send a drawing and I will
see if a set will work.
Mike J.
Old 07-25-2002 | 01:27 PM
add a fuel blader up front with transfer pumps...the AT is ass heavy as it is right now
audacity is offline
Old 07-25-2002 | 01:32 PM
well 25 max of it up there any way...your right 50-75...the sides are the only place....
where the hell r u going....don't ya have 180 gal to start any way???
audacity is offline
Old 07-25-2002 | 02:06 PM
Mike J
JOE,Lighten up I might have a buyer for the tanks
here.
Mike J.
Old 07-25-2002 | 02:12 PM
really it sounds like that is the way he has to go for that kink of fuel requirement....i guess under the engines would work too??? r your fuel safe tanks?...foam or no faom??? what size...
audacity is offline
Old 07-25-2002 | 02:34 PM
ssherman
Joe I am nervous about making the bahamas crossing? I have whate ever is standard. I think I have 150 i think.
Gets a little low on the way to KW if I dont stop midway.
Old 07-25-2002 | 03:21 PM
i have 160 total...do u ever get better than 200miles out of that???
audacity is offline
Old 07-25-2002 | 03:47 PM
ssherman
I have never actually put it in miles.
