Strange "dotted" pattern on valve seats and faces
We were going to install better springs / retainers along with inconel valves in my GM heads, and this is what 5 out of 8 intake valves looked like after 30 hours. The engine builder who took them apart said he has never seen anything like this in 40+ years of building engines. It almost looks like the valve was only sealing in spots on the face. Funny thing was, engine was running fine, and compression check showed 185+ PSI on every cylinder. One thing to note - valve tips all had lines on them where the rocker arm roller tip was beginning to wear into the stems - they were not rotating in the guides.
Pictures:
Has anyone ever seen anything like this? If so, what was the cause?
Pictures:
Registered User
I have seen that before its usually from who ever faced the valves had a lot of chatter When they were grinding them. They needed to face the stone and regrind the valve. Titanium valves do that a lot when facing them if the stone gets loaded up!!!
