engine i.d. 454
I own a 1988 formula 242 ls. with a bravo 1 drive. The engine flame arrester is the old round type wth the mercruiser sticker that says 454 magnum and bravo on it. The intake is not aluminum and the serial # is b960359. Is this a magnum motor with forged internals or not? I looked up the # and it says 7.4L bravo 88-91, but no magnum
Wouldn't be the first time I have seen a 454 MAG flame arrestor on a 7.4. Look at the Max rpm range shown on the sticker on the valve cover. A 7.4 has a upper limit of 4500rpm and the MAG will be 5000rpm. The 7.4 has a ignition rev limiter at 4750rpm and the MAG is 5250rpm. But even so being a 88 there could be a mismatch of parts being it the valve covers or ignition system so at the end of the day the best tell may be the boats performance. What rpm are you running with what prop? What GPS speed?
Just bought the boat. Previous owner said 4800-4900 got 53 -54 gps. More trim and the rpms went up but not the speed. Will have to look for any stickers on the valve covers don't remember any. running a mirage 21. Ignition says thunderbolt.
0B960359 comes up as a MERCRUISER MAGNUM W/ PS 454 BRAVO (454) (1988) Serial No: 0B960359 Model No: 4454110AS
Parts catalog for this serial number,
http://www.mercruiserparts.com/selec...D8+1988%2D1992
You may also want to try and confirm if the serial numbers are the same by checking to see if the Mercruiser engine serial number is stamped into a small metal plate (1" wide X 2" tall) that is usually pinned/riveted to the starboard side of the engine block just above the engine starter towards the rear of the block.
http://www.justanswer.com/view_image...rialNumber.jpg
http://www.google.com/search?q=Locat...ml%3B480%3B640
