Speedometer Issue?
Old 05-06-2013 | 09:49 PM
Default Speedometer Issue?
I just had my outdrive rebuilt (XR) and put Imco -2 lower on (had a regular XR lower before). Speedo was working great before the rebuild, and being a non gps it was actually very accurate (only 4-5 mph off @ 100mph). Since then I have taken the boat out twice and my speedo has been off by around 30 mph @ 60mph. Has anyone had an issue like this? Any suggestions before I take it back to the shop?
Thanks!
DirtyJerz is offline
Old 05-06-2013 | 09:52 PM
BTW, its a Livorsi mph gauge if that matters.
Old 05-06-2013 | 11:15 PM
Sounds like with your X dimension changing the flow to your pilot tube changed as well. Is your pilot tube adjustable? Try dropping it a tad to see what that does.
renodaytona is offline
Old 05-07-2013 | 06:56 AM
Smitty's Avatar
Why not upgrade to a GPS speedo with recall ??? Way more accurate and don't have to watch when making a high spped pass.
Smitty is offline
Old 05-07-2013 | 10:47 AM
Im going to try that, thanks!
I probably am going to do that regardless. I was kicking my self b/c I just bought that speedo last season (needed a higher mph reading), but didnt go with the gps
Anyone need a barely used a 80mph speedo, or a 100mph speedo?
Old 05-07-2013 | 11:59 AM
Ha I wish I had that problem , To fast for my speedo!
Finney is offline
Old 05-07-2013 | 02:36 PM
t500hps's Avatar
21 and 42 footers
I removed my speedo and made a plate to install a 5in screen Garmin map/GPS. Showed my speed but also where the heck I was going!
t500hps is offline
