2003 25' Outlaw W/496HO >
Old 05-07-2013 | 07:51 AM
Default 2003 25' Outlaw W/496HO
I am sure this has been talked to death, but I haven't found what I am looking for on the Threads. So, here is my question.
I have a 2003 25' Outlaw with 496HO. Currently I have a 23P prop. Boat runs 68-69MPH at top speed. Can I change to a different prop and get more MPH. Has anyone tried to do this with this set up and had success?
Loudnoxious is offline
Old 05-07-2013 | 10:24 AM
I'd say you are running at the "top end" of the envelope with those numbers, that's haulin. It takes big power to run the 25/272 into the 70's consistantly.
I'm thinkin the prop MUST already be labbed and you're getting all 425HP/TQ applied very efficently. Either that or your reading those numbers off the wish-o-meter.
Sending that M+23 to Bbladdes prop shop is the best bang for the buck performance wise.
Hook'em is offline
Old 05-07-2013 | 10:28 AM
68-69 MPH on GPS??? thats damn good for that boat.
mittens is offline
Old 05-07-2013 | 12:05 PM
VoodooRob's Avatar
That's haulin' for that set-up. I had a 272 with 454/502 hybrid and I got low 60s with a 25p Mirage Plus. With the 23p Mirage Plus revs were peaking out exactly at 60. I would say run it and leave it alone, you have a solid set-up.
VoodooRob is offline
Old 05-07-2013 | 12:10 PM
Not on GPS. I haven't done that yet. I will next time I take it out. But on the Gauge I have hit 68-69 @4800-5000RPM. I thought 68 was about typical for these boat and motor? The boat usaully cruises at 48-50MPH at 4000RPM.
Old 05-07-2013 | 12:29 PM
ive got an 89 baja with the 500 in it and i get about 68 on a 25 pitch mirage. that 496 is fast!
jvaughn39 is offline
Old 05-07-2013 | 01:16 PM
Your speedometer is off. You aren't going that fast.
Crossett is offline
Old 05-07-2013 | 01:24 PM
This make all your numbers and thoughts you or anyone else wrong.
need real numbers. I have seen 74mph (speedo meter) out of my 252, with a 23mriage, and a454 MAg...... it only did 60-63 (gps) normally.
get some real numbers then bump thread.
mittens is offline
Old 05-07-2013 | 01:52 PM
OK, I will check next time out.
Old 05-07-2013 | 04:31 PM
I have a 502 mag in my 25OL and my speedometer is spot on with my gps. My best was 67 with a light load. 23m+. If you want a mph more or two send your current prop to Bblades and have it labbed. Those guys have a lot of experience labbing props for Bajas.
Fordtough150 is offline
