Bravo 1 gear lube capacity. >
Old 05-12-2013 | 08:04 PM
buck183's Avatar
Default Bravo 1 gear lube capacity.
Getting all my stuff together for my spring service. I guess old age is getting the better of me. Can't for the life of me remember how many quarts of gear lube I need to service a Bravo 1.
Thanks in advance....
buck183 is offline
Old 05-12-2013 | 08:40 PM
Mbam's Avatar
Offshoreonly Advertiser
Here you go
http://www.mercruiserparts.com/tech/...ubeCharts.aspx
Mbam is offline
Old 05-12-2013 | 08:52 PM
Smitty's Avatar
Seriously ??? Alzheimers setting in already ?????
Smitty is offline
Old 05-12-2013 | 09:35 PM
buck183's Avatar
Believe it or not, I have a real long story that contributed to my confusion. Was too long to type out though. Remind me to tell you next time we talk.
Mbam, thank you for the link. It helped a lot.
Buck
buck183 is offline
Old 05-13-2013 | 01:38 AM
7 qts for both drives will be plenty. You will probably only need 6qts depending on how much gets spilled.
BTW, the Quicksilver HP gear lube is exactly the same as the Merc HP gear lube with a different lable. Merc lable is about $18 and QS is $12 at Walmart.
Griff is offline
Old 05-13-2013 | 03:23 AM
Good info
Originally Posted by Mbam
Meshikinquah is offline
Old 05-13-2013 | 11:54 AM
$18 a quart! Where are you buyng your drive oil?? I paid $11.99/qt for Mercury HP drive oil at my local marine supply store over the weekend
low_psi is offline
Old 05-13-2013 | 12:27 PM
just over 3 for each drive. Sometimes guys claim they cant get it all out.
soldier4402 is offline
Old 05-13-2013 | 09:25 PM
buck183's Avatar
Thanks Griff. I'll look into that.
Buck
buck183 is offline
Old 05-14-2013 | 08:50 AM
Become a preferred Amsoil customer and you can get Extreme Gear for $11.95
ThisIsLivin is offline
